Date/Time: Wed, 09 Sep 2026 04:14:03 +0000
statge5 data backfill
View Count: 951
| [2016-03-30 12:42:46] |
| amirN - Posts: 169 |
I am trying to evaluate Stage 5 as a broker. I have opened a demo account with them and had the chart data enabled for my account. Then have selected Gain in Data/trade service setting in SC. Went through file/ find symbol and type YMM6 (YM and ES are not listed). The data backfilled for only two days with price /volume available and the bid/ask volumes set to 0. Stage 5 suggested that I have to talk to SC on how the data is backfilled. Please advise. Thanks |
| [2016-03-30 17:27:24] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings After that is done go to the chart and re-download the data with Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
