Date/Time: Fri, 27 Dec 2024 01:20:03 +0000
windows error code 8
View Count: 1046
[2016-03-30 12:00:33]
User739935 - Posts: 37
in message log keep getting Windows error 8 Not enough storage available to process this command"
i have never had this before
[2016-03-30 16:39:35]
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
[2016-03-30 20:06:37]
Software version: 1389 | 2016-03-30 15:11:59
Uses New Spreadsheets | 2016-03-30 15:11:59
Usage end date: 2016-04-28 | 2016-03-30 15:11:59
Enabled for: Advanced Features. | 2016-03-30 15:11:59
Enabled for: Advanced Features 2. | 2016-03-30 15:11:59
Enabled for: Sierra Chart Historical Data Service. | 2016-03-30 15:11:59
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-03-30 15:11:59
Current selected Data/Trading service: TransAct Trading | 2016-03-30 15:11:59
Chart Update Interval: 900 | 2016-03-30 15:11:59
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-03-30 15:11:59
2016-03-30 15:11:59 Local computer time | 2016-03-30 15:11:59
2016-03-30 19:11:59 Local computer time in UTC | 2016-03-30 15:11:59
2016-03-30 15:11:59 Local computer time in SC Time Zone | 2016-03-30 15:11:59
2016-03-30 11:43:50 Server time in UTC | 2016-03-30 15:11:59
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-03-30 15:11:59
Program path: C:\Documents and Settings\Administrator\Desktop\SierraChart\SierraChartTransAct\2\ | 2016-03-30 15:11:59
Data Files path: C:\SierraChart\SierraChartTransAct\2\data\ | 2016-03-30 15:11:59
OS Version Number: 5.1 | 2016-03-30 15:11:59
Locale Information: C | 2016-03-30 15:11:59
ESM6 5 Min #23 | Error creating offscreen bitmap for chart: Windows error code 8: Not enough storage is available to process this command. | 2016-03-30 16:03:30 *
ESM6 5 Min #23 | Error creating offscreen bitmap for chart: Windows error code 8: Not enough storage is available to process this command. | 2016-03-30 16:03:33 *
Date Time Of Last Edit: 2016-03-31 16:44:34
[2016-03-30 20:32:50]
First time we have seen this reported, at least from what we can remember.
We recommend restarting your computer. That should hopefully solve it.
Another thing you can try is close any unnecessary running programs.
How much RAM does your computer have?
Date Time Of Last Edit: 2016-03-30 20:33:34
[2016-03-31 12:48:27]
restarting my computer seems to have solved the problem
