Date/Time: Mon, 05 Oct 2026 09:02:20 +0000
sc.OpenChartOrGetChartReference and s_ACSOpenChartParameters
View Count: 1157
| [2016-03-30 01:27:29] |
| User99735 - Posts: 234 |
Hi, Am opening a chart using sc.OpenChartOrGetChartReference and s_ACSOpenChartParameters. s_ACSOpenChartParameters has only DaysToLoad parameter to control the number of bars to be loaded in newly opened chart. Opening a fresh chart with 1 days bars takes a while to load. For faster opening / loading of chart, is it possible to open a chart with lets say 20 bars? Regards Vivek |
| [2016-03-30 01:31:24] |
You cannot specify the number of bars. Only the number of Days To Load.
| [2016-03-30 03:20:08] |
| User713273 - Posts: 409 |
Besides looking at bars, is there any way to speed up the download process? Thx
| [2016-03-30 03:56:25] |
Yes, refer to help topic 30.12: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.12 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-30 20:53:50] |
Any negative recourse having multiple historical intraday charts open during trading hrs? Say 25 charts.
| [2016-03-30 20:59:16] |
In the case of Intraday charts not really because these are loaded on a background thread. We would just recommend that you have at least a quad core CPU. And if you can get 6 cores that is even better. You will also want to use a solid-state drive. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
