Date/Time: Sat, 26 Sep 2026 08:13:41 +0000
Screener/Scanner
View Count: 2568
[2016-03-29 19:00:33]
User591995 - Posts: 1
I'd like to initially create an EOD screener/scanner that will created a filtered list based on certain characteristics, then scan or screen that list for certain conditions/criteria. What's the best way to go about this? I've already referenced the documentation.
Thanks!
[2016-03-29 19:23:06]
Here is the documentation for scanning:
https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#Scanning
However this is not supported:
You have to define completely the particular Alert Condition Formula that you want to use from the very start.
