Date/Time: Sun, 20 Sep 2026 23:35:42 +0000
CTV attached to part of the referenced chart?
View Count: 939
[2016-03-29 18:00:42]
User22396 - Posts: 191
Is there a way to imbed the CTV to an area of the chart or float next to the hand kinda like the chart shortcut menu? The reason I ask is when I move an instance of SC to another monitor in a multi-monitor setup the CTV will display on the other monitor. Not sure if there is a way to keep the CTV "within" the SC window so if I move the instance to another monitor the CTV will always display over the referenced chart always in the same area.
Hope this makes sense.
[2016-03-29 18:27:49]
Refer to the documentation here:
Chart Drawing Tools: Compact Tool Values Window
You may want to enable Global Settings >> Tool Settings >> Save Compact Tool Values Window Position for Each Chart.
