Date/Time: Tue, 06 Oct 2026 18:53:07 +0000
Is there a "Global" way to set 'values to display' across all charts?
View Count: 1048
| [2016-03-29 17:37:28] |
| User22396 - Posts: 191 |
I am trying to change which values to display when using the CTV window. Using "Chart Setting>Advanced settings>Settings Button" I can toggle the values but is there a way to globally set which to show as the default or do I have to go into every chart? If no global setting can one be added in an upcoming release? Thanks |
| [2016-03-29 18:30:40] |
No, there is no global setting and this is not something we would add.
