Date/Time: Fri, 18 Sep 2026 06:07:54 +0000
Sierrachart is using the bitfinex data, but there is not ETHERUSD there ??
View Count: 1432
| [2016-03-29 14:49:30] |
| servercookie - Posts: 4 |
Sierrachart is using the bitfinex data, but there is not ETHERUSD there ?? From what i can see in the data list, Sierra gets its crypto data from bitfinex and they have ETHUSD, so why is that not an option in the list when opening Sierracharts? Am i looking in the wrong Place, because i see mostly litecoin and bitcoin but no ETHERUSD there ? Any helpfull suggestions would be helpfull Thanks |
| [2016-03-29 17:45:47] |
We will have to add this symbol.
| [2016-03-29 18:00:10] |
This symbol has now been added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-29 18:27:19] |
Wow Thank you so much, i was a longtime user of sierracharts, and its Nice to see you guys still rock :) Thanks |
| [2016-03-29 19:05:17] |
Just a quick question, i now have the ticker ETHUSD, but only getting 1 day of intraday data. I have selected to show alot more data, but getting a suspicion that perhaps they only provide intraday data (bitfinex) and not historical data at all ? Is that correct ? Thank you again for taking the time to read this |
| [2016-03-29 19:20:50] |
There is only going to be about one day of Intraday data at this time. Since we just set this up . We could see if more historical data is available somewhere. We will check on that later.
| [2016-03-29 19:30:40] |
Thank you
