Date/Time: Fri, 27 Dec 2024 00:36:17 +0000
Re:Your notice
View Count: 733
[2016-03-29 13:35:37] |
tellerbe - Posts: 109 |
How do I know if I am using "new instance" and 'download prerelease"?
[2016-03-29 16:44:49] |
You can disregard that notice. If you are not sure you are using File >> New Instance, then you are not.
