Date/Time: Fri, 27 Dec 2024 01:03:06 +0000
$INX is not streaming real time
View Count: 899
[2016-03-28 18:22:33] |
amangalore - Posts: 23 |
Hi, $INX is not streaming real time. There is a 20 minutes delay. Please check and fix. Thanks Abdulla Mangalore |
[2016-03-28 18:27:34] |
Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-28 18:45:33] |
It was working last week. Not sure what got changed. Can you check please ?
[2016-03-28 18:52:34] |
Your account was activated for the Sierra Chart Exchange Data Feed as a trial for two weeks and that trial has now ended.
[2016-03-28 23:56:03] |
So how do I re-activate after the trial period please ?
[2016-03-29 00:26:28] |
Follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
