Date/Time: Fri, 20 Sep 2024 00:54:45 +0000
API Sierra Chart interface w/ IB Advisor
View Count: 1436
[2013-07-04 23:57:18] |
User49356 - Posts: 9 |
I would like some feedback from anyone who has implemented Sierra Chart w/ IB advisor. |
[2013-07-05 00:44:00] |
JohnL - Posts: 27 |
I use it that way, but I am not able to get the positions to update correctly. It used to work OK, but now I have to check TWS manually for my position information. I've been meaning to spend some more time trying to figure out what is happening. There is thread or two on the old support board on this issue started by me. My usual configuration is to place equal quantity orders from my FA account to two separate U accounts. |
[2013-07-05 01:45:38] |
Update to version 993 and then check the Position Account numbers in Global Settings >> Data/Trade Service Settings. Also you can use trade fill calculated positions: https://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#UsingIndependentInternalPositions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-05 07:36:20] |
JohnL - Posts: 27 |
After updating from 990 to 993, the positions have correctly updated. I haven't checked after a trade yet. Thanks.
