Date/Time: Fri, 18 Sep 2026 20:24:42 +0000
How to add a 3rd party Trend Indicator to my Sierra Study Program???
View Count: 3541
| [2013-07-04 21:25:52] |
| User20200 - Posts: 38 |
Guy's, I have a new study Trend Indicator that is in a zip file, I cannot remember how or the steps to download it into the Sierra Chart file so I can add it to my charts! I need the step by step to copy and paste it into the right file to be able to pull it up through Sierra Charts and add it to my charts... Help me as you always do... Thank you, Team One |
| [2013-07-04 22:34:17] |
This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
