Date/Time: Fri, 27 Dec 2024 00:45:50 +0000
Scrolling moves the position of study
View Count: 695
[2016-03-26 08:58:20] |
User367067 - Posts: 2 |
When I scroll the chart the position of Bollinger bands changes relative to price. None of the different scaling choices solved this problem. Any other settings I missed? |
[2016-03-26 09:55:40] |
Make sure the Scale Range for the Study itself is set to Automatic. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-26 10:54:52] |
Thanks. The study was in auto scale itself , but the price not. It was in independent scale. Now both are in auto and it solved my "issue". |
