Date/Time: Sat, 03 Oct 2026 10:18:08 +0000
Contract volume profile - display number
View Count: 1470
| [2016-03-26 00:16:16] |
| Jason - Posts: 17 |
Hello When displaying a volume profile, is there a way to show the actual number of contracts traded at each price level in addition to the histogram? Thank you |
| [2016-03-26 00:30:54] |
Yes. It is controlled through this Study Input: http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#DisplayVolumeInBars Instructions to control Study Inputs: http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-26 00:31:41
| [2016-03-26 15:38:35] |
| Jason - Posts: 17 |
Thank you for the information. Please excuse me if I am overlooking the answer to my next question as I have not located it. Is it possible to have the volume displayed to the side of the volume profile rather than overlapping it? Thanks again. |
| [2016-03-26 18:15:59] |
Depending upon what you want to do, try using the "Align Volume Numbers to Base of Volume Bars" Input.
