Date/Time: Fri, 20 Sep 2024 00:45:41 +0000
992: URGENT: Any setting you put in data/trade service - Positions account gets overwritten at s
View Count: 1509
[2013-07-04 19:47:24] |
User36173 - Posts: 12 |
992 version of SC trading With interactive brokers, and F account, anything you write in the positions account field at the data/trade services settings screen get replaced automatically anything you have filled in at the positions account with all known U numbers of my F account when you startup SC. It's impossible to work for the moment for me. Thanks for a quick fix. Date Time Of Last Edit: 2013-07-04 19:48:05
[2013-07-04 23:12:00] |
We will be putting out a new release in about an hour or 2 which will resolve this.
[2013-07-05 02:04:26] |
993 has been released.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-05 02:04:38
[2013-07-05 16:59:12] |
Thanks, I traded all day, it's fixed. Thanks for the quickfix.
