Date/Time: Fri, 27 Dec 2024 00:56:50 +0000
reverse session times
View Count: 695
[2016-03-25 20:38:38] |
kinghat - Posts: 120 |
is there an option in the chart settings to reverse session times or are we to manually reverse the session times(start/end and evening start/end)? looking in the docs https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#WhyReverseSessionTimes its not very clear on this.
[2016-03-25 22:50:52] |
You have to manually do this.
