Date/Time: Fri, 27 Dec 2024 00:41:50 +0000
Open two chart at the same time form one chartbook
View Count: 1084
[2016-03-25 16:42:22] |
User134797 - Posts: 52 |
Hi all, I create one chartbook with three chart (2 minute, 5 minute, 10 minute) Is it possible to open two chart at the same time (for example 2 minute, 5 minute)? So I can use them on two different monitors. Best, Iwan |
[2016-03-25 17:07:52] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
