Date/Time: Mon, 14 Sep 2026 08:05:08 +0000
Hiding Chart Drawings
View Count: 1120
| [2016-03-25 12:58:41] |
| User94740 - Posts: 333 |
In version 1354 before upgrading to the current 1385, I was able to hide the drawings on my long-term chart, but able to see them still on my entry chart. Now it has changed that as soon as I hide the drawings on the long-term chart, then they are also hidden on my entry chart. Is this something permanent, because the prior functionality was certainly greatly more favorable.
| [2016-03-26 00:51:29] |
We have to add a new option to control this. This was changed based upon another user request. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-26 21:38:22] |
can you please tell me which version still had the functionality I had mentioned and if there will be any challenges to reinstall? thank you
| [2016-03-26 21:49:38] |
Do not bother with this. We will get this out in a few days. It is an effort for us to answer the question. There is almost never a problem to go back to a prior version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-28 13:44:31] |
ok. if you could please, then leave out the confirmation regarding the hiding of the drawings as is now in the current version. i wonder though if it has purpose for other traders.
Date Time Of Last Edit: 2016-03-28 13:45:44
