Date/Time: Sat, 12 Sep 2026 15:50:04 +0000
Bad data for SPY
View Count: 1056
[2016-03-24 16:55:53]
User960500 - Posts: 1
I am evaluating SC with the default data service. On SPY 5 Min chart, I notice a really huge bar at 5AM on 3/24/2016 (today).
I noticed other anomalous bars in many places. I've tried to deleted and downloaded the data again but they still look wrong.
What am I doing wrong?
Thanks.
[2016-03-24 18:05:57]
Those are not bad bars but normal pricing received from the data feed.
What you need to do is set the Session Times to include only the main trading hours.
Do the following:
Enable Global Settings >> Symbol Settings >> Apply Intraday Session Times To Intraday Chart.
To make sure you have the symbol settings, update the symbol settings as explained here:
Go to the chart and select Chart >> Chart Settings.
Press the Apply Global Symbol Settings button.
Uncheck the Use Evening Session option.
Press OK.
