Date/Time: Fri, 02 Oct 2026 18:26:31 +0000
ContinousContract
View Count: 1748
| [2013-07-04 16:51:10] |
| User25778 - Posts: 4 |
Hi, I got a Q about continous contract @. Is back-adjusted data or not? thank you. |
| [2013-07-04 23:14:13] |
Only if you use DTN IQ Feed will this be the case. This is a longer-term feature we do plan to implement ourselves. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
