Date/Time: Tue, 06 Oct 2026 07:17:14 +0000
How to cretae bracket orders
View Count: 1470
[2016-03-24 15:11:03]
User134797 - Posts: 56
Hi All,
How can create and send a bracket to the market.
1) A buy order
2) A sell order to take profit
3) A stop order to take my loss
Best,
Iwan
[2016-03-24 15:45:55]
User48557 - Posts: 138
Click ''trade'' at the top of your screen. Then click ''open trade window for chart'' . At the top make sure the settings are set to '' simple bracket'' . Then go to ''trade'' again and select ''chart trade mode on'' . Then you should be able to just right click on that chart and select buy or sell limit and your bracket will be created.
[2016-03-24 17:29:40]
The answer given at post #2 is from a user and not Sierra Chart support.
What you are looking for are called Attached Orders and they are documented on this page:
Attached Orders
