Date/Time: Fri, 27 Dec 2024 01:15:10 +0000
orders on chart
View Count: 678
[2016-03-23 14:58:35]
User97392 - Posts: 1
I trade from the DOM but like to see the orders on my chart. This worked last week and doesn't now, not sure what changed. I downloaded the new version 1385. I have a check under the trade menu to show orders and positions. Also checked is trade simulation mode on and auto trading enabled. The instrument (YMM6) is the same on the chart as on the DOM. What else should I look for?
[2016-03-23 16:58:41]
Follow through the instructions here if you are using TransAct:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#Trading
Make sure you uncheck Trade >>Trade Simulation Mode On.
