Date/Time: Sun, 20 Sep 2026 18:15:31 +0000
re post 19913
View Count: 1023
[2016-03-23 00:55:26]
User705641 - Posts: 38
thankyou I understand finding the area but i want to know what values to enter to get only the round numbers and the 50's and where specifically the info on this can be found I have tried without success
Also can you reduce the size of a profile hard on the right side of the screen so that it does not extend half way across the screen
[2016-03-23 01:07:01]
Open the Scale Settings window:
Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph
Enter 50 for the Scale Increment.
Specifically what do you mean by "profile"?
[2016-03-23 01:29:12]
I have a volume by price set on the right side of the screen and I wanted to know if you can reduce how far the display extends to the left on the screen. ie scrunch it up
[2016-03-23 02:34:17]
http://www.sierrachart.com/image.php?l=1458700343380.png
I want to reduce the VbP on the right
[2016-03-23 04:42:51]
Yes this is controlled with the following Study Inputs:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#MaximumVolumeBarWidthType
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#MaximumVolumeBarWidthPercentage
