Date/Time: Sat, 12 Sep 2026 11:05:03 +0000
F1 Shortcut key problem - it also opens help page
View Count: 1967
| [2013-07-04 10:31:53] |
| JP - Posts: 24 |
I have configured F1 as a keyboard shortcut for a specific tool but every time I press F1 it also opens the web browser with the Sierra chart working with charts page. --> Is there a way to disable sierra to open this help page when pressing F1? Thank you |
| [2013-07-04 10:40:40] |
| ganz - Posts: 1048 |
JP hi Keyboard-shortcut on F1 key gd lck |
| [2013-07-04 10:54:14] |
| JP - Posts: 24 |
Thank you Ganz.
| [2013-07-06 01:18:12] |
No, there is not. You need to avoid using that shortcut key for anything else.
| [2014-01-02 12:23:41] |
| User37462 - Posts: 33 |
Hello, I have similar problem. For example shortcuts for Extending rectangle Ctrl -Alt -T starts another program in windows but not drawing rectangle. I have also problem with another shortcuts. Any help? Many thanks Jiri |
| [2014-01-03 05:34:29] |
In response to post #5, it sounds as though you have some global system-level shortcuts set up to start programs. This is something that is not within our control . This is something you need to solve on your side. We are not familiar with your system.
| [2015-04-23 23:10:46] |
| User623839 - Posts: 108 |
Still no resolution for the F1 key?
| [2015-04-23 23:45:20] |
No. And do not expect this.
| [2015-04-24 01:44:07] |
thanks
