Date/Time: Fri, 27 Dec 2024 01:07:22 +0000
Line on Close style
View Count: 864
[2016-03-22 14:01:51] |
User842703 - Posts: 55 |
Under Global Settings/Graphics the Line on Close option has the Line Style function greyed out. Is there any way to change this? I would like the style to be dots.
[2016-03-23 12:03:19] |
Bump
[2016-03-23 14:45:32] |
Sawtooth - Posts: 4143 |
Try this workaround: -Add the Moving Average - Simple study, set the length to 1, set the Draw Style to your preference. -In the Chart Settings, set the Graph Draw Type to Blank. This also allows you to color the line based on slope. |
[2016-03-23 17:19:22] |
We will program this now.
[2016-03-23 18:14:09] |
@tomgilb Thanks, I already tried that using Dots as the 1 period MA but they don't align very well with the actual price line on close. Hopefully it will work after SC re-program so I can insert an MA 1 line over the price close dots.
