Date/Time: Wed, 16 Sep 2026 07:17:02 +0000
CTS T4 Connection error
View Count: 2136
| [2013-07-04 08:12:40] |
| ferasmu - Posts: 3 |
I get the following message when trying to connect to the T4 data service. I run SierraChart under Ubuntu/Wine, but have been advised that I need to run the CLR version in order to connect to CTS T4. (previously running the non-CLR version, it just would not connect at all) Here is the new error message in my log since running the Prerelease CLR version. Connecting to CTS T4 Simulation server. | 2013-07-04 09:08:39 CTS T4 Service: Error connecting to CTS T4. Exception message: Could not load file or assembly 'System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. Exception from HRESULT: 0x80070002 | 2013-07-04 09:08:39 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-07-04 09:08:39 To prevent further connection attempts, select File >> Disconnect. | 2013-07-04 09:08:39 Disconnected from CTS T4. | 2013-07-04 09:08:40 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-07-04 09:08:40 File >> Disconnect selected. | 2013-07-04 09:08:43 Disconnected from CTS T4. | 2013-07-04 09:08:43 Thanks for any assistance. |
| [2013-07-04 08:39:44] |
We cannot help with this. If you are using a non-Windows operating system, then we cannot help. The problem you have is totally outside of the Sierra Chart software. Please wait about 2 weeks when we release the FIX connection to T4. You will not experience this kind of problem with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
