Date/Time: Fri, 27 Dec 2024 00:41:16 +0000
data window
View Count: 1157
[2016-03-22 06:35:01] |
stephensmart - Posts: 51 |
Hi, I have my cursor set to chart values/crosshair, previosuly when i clicked on the chart i got the crosshair lines up and it brought up a data window showing high low etc for bars i was on, now when i click there is no data block, is this due to the latest upgrade?
[2016-03-22 09:31:29] |
This is the Window >> Show Compact Tool Values Window. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CannotSeeValuesWindows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-22 09:32:14
