Date/Time: Fri, 27 Dec 2024 00:26:33 +0000
new attached order
View Count: 702
[2016-03-21 20:24:47]
aydex - Posts: 110
From the page linked below it says
"If you want to start completely fresh with your own Attached Order configuration,"
and then it goes on to say remove all existing.
I would like to keep the existing twconfig and add to it
The figure shown at this link
http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#AttachedOrdersExample1
depicts the top field as blank, how is this done?
I'm after how to add to an existing twconfig
-J
[2016-03-22 05:00:04]
Follow through the instructions here to configure the Attached Orders as required:
http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#Instructions
For the existing Attached Orders which are already there, just simply modify them. You do not have to remove them. Go through the step-by-step instructions and you will see how to modify them. Whether they are new or existing, how the settings are changed for individual Attached Orders remains the same.
Once you are done with that, then save the Trade Window configuration as explained here:
http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#PreconfiguredAttachedOrdersSet
Date Time Of Last Edit: 2016-03-22 05:02:20
