Date/Time: Sun, 04 Oct 2026 04:18:35 +0000
ACSIL: UseTool
View Count: 6730
[2016-03-21 16:53:36]
User53601 - Posts: 107
In some price configurations I display some text via UseTool.
Having the text drawing tool displayed by the study, usually I could move the text manually throught the chart.
For some reason, I can not move it any more. The drawing text is fixed on the chart and I cannt move it manually away, to other place on the chart.
I don’t guess what has changed, or if I changed unintentionaly some setting.
Can you advise where could be the reason.
Here is the code part of the code:
s_UseTool LineTradeCode;
LineTradeCode.Clear();
LineTradeCode.DrawingType = DRAWING_TEXT;
LineTradeCode.AddMethod = UTAM_ADD_OR_ADJUST;
LineTradeCode.AddAsUserDrawnDrawing = 1;
Thank you
[2016-03-22 09:01:04]
Here is a code example we put together and tested to work:
SCSFExport scsf_UseToolExampleText(SCStudyInterfaceRef sc)
  // Set configuration variables
  if (sc.SetDefaults)
    sc.GraphName = "UseTool Example: Text";
    sc.StudyDescription = "User drawn text drawing example.";
    sc.GraphRegion = 0;
    sc.FreeDLL = 0;
    sc.AutoLoop = 0; //No automatic looping
    return;
  int &TextDrawingLineNumber = sc.GetPersistentInt(1);
  if (TextDrawingLineNumber != 0 && sc.LastCallToFunction)
    // Be sure to remove the Text drawing added as a user drawn drawing
    sc.DeleteUserDrawnACSDrawing(sc.ChartNumber, TextDrawingLineNumber);
    return;//No further processing needed in this case.
  // Do data processing
  int BarIndex = sc.ArraySize - 20;
  if (BarIndex < 0)
    return;
  s_UseTool TextDrawing;
  TextDrawing.Clear();//Not necessary but good practice
  TextDrawing.ChartNumber = sc.ChartNumber;
  TextDrawing.DrawingType = DRAWING_TEXT;
  if(TextDrawingLineNumber != 0)
    TextDrawing.LineNumber = TextDrawingLineNumber;
  TextDrawing.AddAsUserDrawnDrawing = 1;
  TextDrawing.BeginIndex = BarIndex;
  TextDrawing.BeginValue = sc.High[BarIndex];
  TextDrawing.Color = COLOR_KHAKI;
  TextDrawing.Text = "Movable User Drawn Text Example";
  TextDrawing.FontSize = 18;
  // do not keep adjusting
  TextDrawing.AddMethod = UTAM_ADD_ONLY_IF_NEW;
  sc.UseTool(TextDrawing);
  //Remember the line number which has been automatically assigned
  TextDrawingLineNumber = TextDrawing.LineNumber;
To move the text drawing make sure a non-drawing tool is selected like Tools >> Pointer.
Make sure you also have not locked the drawing.
Date Time Of Last Edit: 2016-03-22 09:03:29
[2016-03-25 18:53:37]
Thank you for the code, I used it for testing, and it brought me to the solution.
I have more of my own studies on the chart.
The source of the problem was in one of them.
In one of the study I deleted user drawing without prior testing whether the drawing exists.
By replacing sc.DeleteUserDrawnACSDrawing
with
if sc.ChartDrawingExists then sc.DeleteUserDrawnACSDrawing
the problem dissapperaed.
I did not guess two studies in one chart could be interconnected in such a way.
thank you again for the support.
Date Time Of Last Edit: 2016-03-25 18:56:22
