Date/Time: Fri, 27 Dec 2024 01:26:47 +0000
Price Marker
View Count: 1016
[2016-03-21 16:23:35] |
User21113 - Posts: 62 |
Is there a feature to add a price marker on a chart. For instance, through Tools > More Tools > Marker you are able to place a dash or dot at any place on the chart. However there is no option to place a price instead of a a dash or dot. Is this possible in any feature of Sierra Chart? |
[2016-03-21 18:13:44] |
For this use the Type Text tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#TypeText And enter a price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
