Date/Time: Fri, 27 Dec 2024 00:38:11 +0000
DOM COLUMNS MOVING
View Count: 721
[2016-03-21 15:49:00] |
User638756 - Posts: 52 |
Is there a way to get the Dom columns to stop moving?
[2016-03-21 18:03:19] |
We wonder if this is related to the Constant Range Scale changes that have been made. Follow the instructions here to open the Scale Settings window: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowMainPriceGraph What is the Scale Range set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
