Date/Time: Mon, 05 Oct 2026 16:10:16 +0000
simple daily high low
View Count: 1683
[2016-03-21 11:00:06]
EuropeanTrader - Posts: 290
Hello everyone,
can somebody please help me with such a simple issue I am even embarrased to ask.
I want simple daily high low lines displayed exactly as these value are lines. No lines overnight or verticaly shown or even to be drawn while they changed with each intraday bar.
These are value area lines and look great.
http://www.sierrachart.com/image.php?l=1458557692433.png
Now I want daily high and low like this added (see attached pic). I draw black lines that draw only for that day.
How can I do that?
Thank you!
imagehlll.png / V - Attached On 2016-03-21 11:00:02 UTC - Size: 58.69 KB - 619 views
[2016-03-21 16:36:36]
User48557 - Posts: 138
''Daily OHLC '' study. Then under subgraphs you can set the open and close to ''ignore'' and change the high and low line colours to black.
[2016-03-21 17:29:42]
yeah, thanks, but the problem is that I get these vertical lines shown. pls see:
http://www.sierrachart.com/image.php?l=1458581373692.png
[2016-03-21 17:36:04]
set the ''draw style'' to ''dash''
imagedash.PNG / V - Attached On 2016-03-21 17:35:54 UTC - Size: 48.19 KB - 427 views
[2016-03-21 19:17:59]
Use the Daily OHLC study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137
As has been said set the Draw Style to "Dash".
Date Time Of Last Edit: 2016-03-21 19:19:27
[2016-03-22 15:02:47]
Thank you to both of you - it works awesome!
