DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
 - Search Board |
 - Control Panel |
 - View My Posts / Threads |
 - Direct Messages
Date/Time: Tue, 04 Nov 2025 11:13:54 +0000
MarketDataRequest to subscribe to symbols
View Count: 4270
|   [2016-03-21 09:18:04]     |
| vbmithr - Posts: 204 |
                Using latest SC, it seems that it sends HistoricalDataRequest messages but not MarketDataRequest anymore. Do you have an explanation for that or it is my code that is buggy?  |
|   [2016-03-21 20:24:49]     |
                If this were an actual problem with Sierra Chart itself we would be having thousands of complaints already. We do not have any. Check your code. Date Time Of Last Edit: 2016-03-21 20:25:01
|   [2016-03-22 01:05:03]     |
                You added a field in the LogonResponse structure, I did not know that. This was breaking change. Any way to be informed when there is protocol updates?
|   [2016-03-22 04:02:23]     |
                OK yes that is true. This is s_LogonResponse::MarketDataSupported. We had not thought of that.  The best thing to do is to look at the changes on github: https://github.com/DTC-protocol  |
|   [2020-12-23 10:10:58]     |
| RoadKill - Posts: 38 |
                Where did it go?
|   [2021-01-03 22:23:17]     |
                The Github repository is not maintained anymore.  The current set of files is located here: https://dtcprotocol.org/#DTCFiles  |
