Date/Time: Thu, 24 Sep 2026 14:02:51 +0000
Get value of s_UseTool struct
View Count: 1147
[2016-03-19 16:12:43]
User96015 - Posts: 55
Dear sir,
I' d like to get the current value of Tool which was plotted by code.
Thank in advice.
[2016-03-19 17:52:05]
We do not understand the question. You can access the individual members of the structure. They are all documented here:
Using Drawing Tools From an Advanced Custom Study: Using Tools with sc.UseTool()
[2016-03-21 07:37:20]
Ok.
Ex:
I plot a Fibonacci Fan with s_UseTool struct, then I' d like to get the current value of every Retracement Levels for the current bar.
How can I do it?
Thank in advice.
[2016-03-21 09:53:31]
If that is a User Drawn chart drawing, then you can use this function:
Using Drawing Tools From an Advanced Custom Study: sc.GetUserDrawnChartDrawing()
