Date/Time: Fri, 27 Dec 2024 01:12:03 +0000
Looking for New Highs New Lows indicator
View Count: 1455
[2016-03-18 21:43:00] |
User623839 - Posts: 108 |
Something like whats attached. I am currently using the HH/LL but it acts as a channel and I just want a simple line only to plot when a new high or low is made
Screen Shot 03-18-16 at 04.39 PM.PNG / V - Attached On 2016-03-18 21:41:55 UTC - Size: 11.85 KB - 349 views |
[2016-03-19 20:24:36] |
The lines can go all the way across. That would be fine also. I just don't want the channel the HH/LL plots |
[2016-03-21 23:45:51] |
Anyone? Bueller?
[2016-03-22 00:38:10] |
Sawtooth - Posts: 4143 |
Use the Daily OHLC study, set the Reference Days Back to 0, set the Graph High and Low Historically to Yes set the Draw Style of SG1 and SG4 to Ignore. |
[2016-03-22 20:18:08] |
Tomgilb, you are too kind :)
