Date/Time: Tue, 06 Oct 2026 13:22:48 +0000
Need a alert sound when a pivot point is reached.
View Count: 1167
| [2016-03-18 21:09:28] |
| User48557 - Posts: 138 |
I looked through the ''alert formula examples'' and I cannot find that specific formula. If anybody knows that formula off hand please share
| [2016-03-19 18:46:48] |
I am also looking for a alert sound for every time the market hits the prior days high or low. so far i have the study ''period OHLC-variable period'' open and it shows me the prior days high and low . What would i put in the ''alerts'' section to get a alert every time one of those levels are touched? I would imagine this would be similar to the pivot point alert that i am still waiting to get some help on.
| [2016-03-20 09:36:24] |
Basically you will want to use the CROSSOVER function. So you will want to use something like this: = OR( CROSSOVER(SG1,C), CROSSOVER(SG2,C) ) You can add additional CROSSOVER functions in the OR function. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-20 09:36:35
