Date/Time: Fri, 27 Dec 2024 00:58:09 +0000
Color Bar Help
View Count: 795
[2016-03-18 16:31:44] |
User785574 - Posts: 3 |
Hello Support Board. I have at this for 3 days now. I cant figure out whats wrong. I created a study using the Cumulative Sum Study. I want to color the bars with values above zero and color the bars below zero from this study. The Bars will NOT color. I changed the study to use background to test the study. That works great. When i change it back to color bars nothing happens??? Any suggestions. Follow up: I have been using the COLOR BAR Based On Above Below Study. Thinking there might might be some snag with some other indicators. So i started to delete them. When i deleted all my Volume Profiles. The Color Bar Study Works???? Date Time Of Last Edit: 2016-03-18 16:40:07
[2016-03-18 17:26:56] |
You should use the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 However, the problem sounds like an issue with the display order of studies. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#StudyDisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
