Date/Time: Fri, 27 Dec 2024 00:24:34 +0000
Recreate a chart I saw online
View Count: 1117
[2016-03-18 15:14:31]
User380978 - Posts: 25
Hi, I attachrf this chart on this message, which is what I've been able to accomplish so far, but I want it to look like the one that I am sharing on this link, where VWAP, VAH, VAL, and POC numbers show align to where they suppose to be instead of in the top, any help will be greatly appreciate it.
http://www.mapleleafnj.com/wp-content/uploads/2016/01/Screen-Shot-2016-01-27-at-1.42.54-PM.png
imageVPOC_Sample.jpg / V - Attached On 2016-03-18 15:13:29 UTC - Size: 367.38 KB - 349 views
[2016-03-18 17:19:42]
Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#CalculatingDisplayingDevelopingPOC_VAHL_VWAP
[2016-03-18 17:29:17]
Thanks for your quick response,
I did that as instructed, even before you send me this instructions, here are my settings which technically speaking should be showing as intend but they do not.
Attached settings
Date Time Of Last Edit: 2016-03-18 17:31:28
imageVPOC Sample Settings.jpg / V - Attached On 2016-03-18 17:31:16 UTC - Size: 449.59 KB - 295 views
[2016-03-18 17:48:54]
It appears you did not follow step 3 here:
Here is another way to do this:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#POCAndValueAreaExtensionLineLabels
[2016-03-19 02:00:27]
Thank you so much!!!
I used the second option it was exactly what I wanted.
Thanks!!
