Date/Time: Mon, 06 Jan 2025 09:18:59 +0000
italy 40
View Count: 817
[2016-03-18 08:13:05] |
User60358 - Posts: 47 |
Italy 40 doesn't work . Thanks
[2016-03-18 08:33:29] |
We do see the problem. The FXCM data feed is not transmitting this data for this symbol today for reasons which we are not sure about.
[2016-06-22 09:32:44] |
ITALY 40 doesn't work yet
[2016-06-22 09:37:25] |
FXCM, where the data originates from, has discontinued market data and trading for this symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-22 09:38:07
