Date/Time: Fri, 27 Dec 2024 01:58:33 +0000
User 944436
View Count: 602
[2016-03-17 22:34:16] |
User944436 - Posts: 7 |
Hello,I Trial Package,and failed data connect,I tried to turn off Win.Firewall,no. Thank you for your help. |
[2016-03-17 22:44:43] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
