Date/Time: Fri, 27 Dec 2024 02:16:20 +0000
REF:T Sep 16 Crude Oil WTI
View Count: 664
[2016-03-17 16:15:20] |
User511640 - Posts: 1 |
No data? could someone pls check? many thanks d. Date Time Of Last Edit: 2016-03-17 16:15:33
sierrabugs.png / V - Attached On 2016-03-17 16:15:10 UTC - Size: 8.49 KB - 262 views |
[2016-03-17 16:43:50] |
We are checking this.
[2016-03-17 16:52:41] |
We see the data: http://www.sierrachart.com/image.php?l=1458233476980.png It appears you are not using the right symbol format. Perform a Full Reset of the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps After this is done open a new chart through the File >> Find Symbol and use the symbol listed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-17 16:53:03
