Date/Time: Fri, 20 Sep 2024 01:10:01 +0000
Open Range
View Count: 1562
[2013-07-03 15:43:37] |
Jerry J Sears - Posts: 27 |
Hi, Is there a indicator or study that would add and subtract 10 points or 40 ticks to the high, low and average of a market open candle. Let me know, Thanks, Jerry |
[2013-07-04 00:19:21] |
This can be accomplished by using a combination of the following studies: Study Subgraph Add High/Low for Time Period Refer to Technical Studies Reference for additional information: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-04 11:38:00] |
Cool, can it be displayed on the main graph? Let me know, Jerry |
[2013-07-04 18:43:50] |
Yes. This is the default location for High/Low for Time Period . You need to use the Chart Region setting in the Study Settings window to control this. Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#ChartRegion Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
