Date/Time: Fri, 27 Dec 2024 02:08:27 +0000
User Email
View Count: 744
[2016-03-17 15:10:44] |
Sierra Chart - Max - Posts: 5769 |
I have just purchased aditional time for using SC, specifically package 5. After opening SC, I have received a log message about the HTTPS connection shut down. I am attaching the complete log out message. Would you please help me resolve this? Is it necessary to do anything with my computer settings perhaps for firewall or something like it? Thank you for your reply. Best regards, Sierra Chart Support |
Untitled.png / V - Attached On 2016-03-17 15:10:36 UTC - Size: 604.81 KB - 276 views |
[2016-03-17 17:07:22] |
What you see is normal. Disregard those messages. However, you are running an older version. Update Sierra Chart following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
