Date/Time: Fri, 27 Dec 2024 01:47:52 +0000
MISSING DATA
View Count: 731
[2016-03-17 12:29:18] |
Meritus - Posts: 164 |
http://www.sierrachart.com/image.php?l=1458217316825.png http://www.sierrachart.com/image.php?l=1458217980361.png Hello Support, I use CTS for Eurex but for some reason the SC March 16 FESX chart stopped updating around 18:00 London time on 16/3 but the SC June Contract is updating ok. The March contract has not yet rolled and my CTS trading DOM is updating properly. I have spoken to CTS and they advised I contact you so can you please advise. Thanks *To clarify, the SC charts I have uploaded shows the March contract which has stopped updating on a daily or intraday period and the June contract which has all data. Front end for March and chart for March from CTS have no issues I have tried edit / download and reload charts but nothing Date Time Of Last Edit: 2016-03-17 12:37:32
[2016-03-17 16:58:27] |
Select Global Settings >> Data/Trade Service Settings. Set the Data Throughput and Buffering to "Fast Trade". Follow the instructions here to clear the Message Log: https://www.sierrachart.com/index.php?page=doc/doc_MessageLog.html#Clearing Reconnect to the data feed: https://www.sierrachart.com/index.php?page=doc/doc_FileMenu.html#ProcedureToReconnect Post a copy of the Message Log by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-17 16:58:52
[2016-03-17 17:16:55] |
Software version: 1374 | 2016-03-17 17:14:52 Uses New Spreadsheets | 2016-03-17 17:14:52 Usage end date: 2016-03-19 | 2016-03-17 17:14:52 Enabled for: Advanced Features. | 2016-03-17 17:14:52 Enabled for: Sierra Chart Historical Data Service. | 2016-03-17 17:14:52 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2016-03-17 17:14:52 Enabled for: INDEXES_DATA_BARCHART | 2016-03-17 17:14:52 Enabled for: CME (Trading Account Required) | 2016-03-17 17:14:52 Enabled for: CBOT (Trading Account Required) | 2016-03-17 17:14:52 Enabled for: COMEX (Trading Account Required) | 2016-03-17 17:14:52 Enabled for: NYMEX (Trading Account Required) | 2016-03-17 17:14:52 Enabled for: ICE Europe | 2016-03-17 17:14:52 Received 1 data feed usernames. | 2016-03-17 17:14:52 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-03-17 17:14:52 Current selected Data/Trading service: CTS T4 FIX | 2016-03-17 17:14:52 Chart Update Interval: 500 | 2016-03-17 17:14:52 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2016-03-17 17:14:52 2016-03-17 17:14:52 Local computer time | 2016-03-17 17:14:52 2016-03-17 17:14:52 Local computer time in UTC | 2016-03-17 17:14:52 2016-03-17 17:14:52 Local computer time in SC Time Zone | 2016-03-17 17:14:52 2016-03-17 07:46:20 Server time in UTC | 2016-03-17 17:14:52 Local computer UTC time and Server UTC time difference: 4 seconds. | 2016-03-17 17:14:52 Program path: C:\SierraChart\ | 2016-03-17 17:14:52 Data Files path: C:\Users\capitaleast\Documents\New folder\SC2\ | 2016-03-17 17:14:52 OS Version Number: 6.2 | 2016-03-17 17:14:52 Locale Information: C | 2016-03-17 17:14:52 File >> Disconnect selected. | 2016-03-17 17:15:25 CTS FIX: DisconnectFIX called. | 2016-03-17 17:15:25 CTS FIX: Sending a Logout message. | 2016-03-17 17:15:25 Socket (9) | Shutdown and closed. | 2016-03-17 17:15:25 SC Data - All Services | Disconnected from the server. | 2016-03-17 17:15:25 CTS T4 FIX | Disconnected. | 2016-03-17 17:15:25 CTS FIX: Disconnected. | 2016-03-17 17:15:25 CTS FIX: Received a Logout message. Text = Successful logout upon request | 2016-03-17 17:15:25 CTS FIX socket (7) | SSL shutdown indicates not able to send 'close notify'. | 2016-03-17 17:15:25 CTS FIX socket (7) | SSL has been shut down. | 2016-03-17 17:15:25 CTS FIX socket (7) | SSL object has been freed. SSL state is now disconnected. | 2016-03-17 17:15:25 CTS FIX socket (7) | Shutdown and closed. | 2016-03-17 17:15:25 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2016-03-17 17:15:34 CTS FIX - Firm: Dorman | 2016-03-17 17:15:34 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106. | 2016-03-17 17:15:34 CTS FIX socket (317) | Connected. | 2016-03-17 17:15:34 CTS FIX socket (317) | Starting TLS 1.0 connection. | 2016-03-17 17:15:34 CTS FIX socket (317) | Ignored Write event based on current socket state. | 2016-03-17 17:15:34 CTS FIX socket (317) | SSL connection established. | 2016-03-17 17:15:34 CTS FIX: Sending the Logon message. | 2016-03-17 17:15:34 CTS FIX | FIX version: 4.3.49.0 | 2016-03-17 17:15:34 CTS T4 FIX | Connected to data and trading server. | 2016-03-17 17:15:34 Mapping G.20160400.ICE_IC to LFJ16. Service code: ice.eu | 2016-03-17 17:15:34 Mapping G.20160400.ICE_IC-baavg to LFJ16. Service code: ice.eu | 2016-03-17 17:15:34 Supporting real-time market data updates for child symbol: G.20160400.ICE_IC-baavg | 2016-03-17 17:15:34 SC Data - All Services | Starting real-time market data updates for: LFJ16. ID: 1 | 2016-03-17 17:15:34 SC Data - All Services | Using username 0 | 2016-03-17 17:15:34 SC Data - All Services | Connecting to the server scdf1.sierracharts.com. Port 10048 | 2016-03-17 17:15:34 Intraday data recording state for symbol G.20160400.ICE_IC-baavg is set to download 'Pending'. | 2016-03-17 17:15:34 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-03-17 17:15:34 HD Request # 30 | Downloading Intraday chart data for G.20160400.ICE_IC-baavg to the file G.20160400.ICE_IC-baavg.scid. Service: ice.eu | 2016-03-17 17:15:34 HD Request # 30 | Download start Date-Time: 2016-03-17 17:15:22.000 | 2016-03-17 17:15:34 CTS T4 FIX | Starting real-time market data updates for: FDAX.20160300.E_INX. ID: 3 | 2016-03-17 17:15:34 CTS T4 FIX | Using primary service for historical data for FDAX.20160300.E_INX | 2016-03-17 17:15:34 Intraday data recording state for symbol FDAX.20160300.E_INX is set to download 'Pending'. | 2016-03-17 17:15:34 HD Request # 31 | Downloading Intraday chart data for FDAX.20160300.E_INX to the file FDAX.20160300.E_INX.scid. Service: cts | 2016-03-17 17:15:34 HD Request # 31 | Download start Date-Time: 2016-03-17 17:15:21.000 | 2016-03-17 17:15:34 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2016-03-17 17:15:34 Mapping G.20160600.ICE_IC to LFM16. Service code: ice.eu | 2016-03-17 17:15:34 SC Data - All Services | Starting real-time market data updates for: LFM16. ID: 4 | 2016-03-17 17:15:34 Intraday data recording state for symbol G.20160600.ICE_IC is set to download 'Pending'. | 2016-03-17 17:15:34 CTS T4 FIX | Starting real-time market data updates for: FGBL.20160600.E_BND. ID: 5 | 2016-03-17 17:15:34 CTS T4 FIX | Using primary service for historical data for FGBL.20160600.E_BND | 2016-03-17 17:15:34 HD Request # 30 | Using server: scdf2.sierracharts.com port 10149 | 2016-03-17 17:15:34 Intraday data recording state for symbol FGBL.20160600.E_BND is set to download 'Pending'. | 2016-03-17 17:15:34 Intraday data recording state for symbol G.20160400.ICE_IC is set to download 'Pending'. | 2016-03-17 17:15:35 Mapping G.20160500.ICE_IC to LFK16. Service code: ice.eu | 2016-03-17 17:15:35 SC Data - All Services | Starting real-time market data updates for: LFK16. ID: 6 | 2016-03-17 17:15:35 Intraday data recording state for symbol G.20160500.ICE_IC is set to download 'Pending'. | 2016-03-17 17:15:35 Mapping HO.20160400.CME_NY to HOJ16. Service code: nymex | 2016-03-17 17:15:35 SC Data - All Services | Starting real-time market data updates for: HOJ16. ID: 7 | 2016-03-17 17:15:35 Starting updates for: HO.20160400.CME_NY-baavg | 2016-03-17 17:15:35 Mapping HO.20160400.CME_NY-baavg to HOJ16. Service code: nymex | 2016-03-17 17:15:35 Intraday data recording state for symbol HO.20160400.CME_NY-baavg is set to download 'Pending'. | 2016-03-17 17:15:35 Mapping HO.20160600.CME_NY to HOM16. Service code: nymex | 2016-03-17 17:15:35 SC Data - All Services | Starting real-time market data updates for: HOM16. ID: 9 | 2016-03-17 17:15:35 Starting updates for: HO.20160600.CME_NY-baavg | 2016-03-17 17:15:35 Mapping HO.20160600.CME_NY-baavg to HOM16. Service code: nymex | 2016-03-17 17:15:35 Intraday data recording state for symbol HO.20160600.CME_NY-baavg is set to download 'Pending'. | 2016-03-17 17:15:35 Starting updates for: G.20160500.ICE_IC-baavg | 2016-03-17 17:15:35 Mapping G.20160500.ICE_IC-baavg to LFK16. Service code: ice.eu | 2016-03-17 17:15:35 Intraday data recording state for symbol G.20160500.ICE_IC-baavg is set to download 'Pending'. | 2016-03-17 17:15:35 CTS T4 FIX | Starting real-time market data updates for: FGBX.20160600.E_BND. ID: 12 | 2016-03-17 17:15:35 CTS T4 FIX | Using primary service for historical data for FGBX.20160600.E_BND | 2016-03-17 17:15:35 Intraday data recording state for symbol FGBX.20160600.E_BND is set to download 'Pending'. | 2016-03-17 17:15:35 CTS FIX: Received Account List collateral report. | 2016-03-17 17:15:35 CTS FIX: Subscribing to account: 36* | 2016-03-17 17:15:35 Socket (318) | Connected. | 2016-03-17 17:15:35 SC Data - All Services | Connected to server. | 2016-03-17 17:15:35 SC Data - All Services | Sending Encoding Request to server | 2016-03-17 17:15:35 CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 69.44.110.227. | 2016-03-17 17:15:35 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-03-17 17:15:35 Supported exchange: L_J (Euronext Paris Index Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_IC (ICE EU Futures) | 2016-03-17 17:15:35 Supported exchange: L_Y (Euronext Paris Commodity Futures) | 2016-03-17 17:15:35 Supported exchange: CME_ELE (NYMEX Power Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_WOp (ICE Canada Options) | 2016-03-17 17:15:35 Supported exchange: L_YOp (Euronext Paris Commodity Options) | 2016-03-17 17:15:35 Supported exchange: E_INXOp (Eurex Index Options) | 2016-03-17 17:15:35 Supported exchange: CME_FRE (NYMEX Freight Futures) | 2016-03-17 17:15:35 Supported exchange: CME_KOp (KCBT Options) | 2016-03-17 17:15:35 Supported exchange: CME_HoOp (CME Housing Options) | 2016-03-17 17:15:35 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2016-03-17 17:15:35 Supported exchange: ICE_ICOp (ICE EU Options) | 2016-03-17 17:15:35 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2016-03-17 17:15:35 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2016-03-17 17:15:35 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2016-03-17 17:15:35 Supported exchange: CME_COp (CBOT Commodity Options) | 2016-03-17 17:15:35 Supported exchange: CME_EqOp (CME Equity Options) | 2016-03-17 17:15:35 Supported exchange: E_VOL (Eurex Volatility Futures) | 2016-03-17 17:15:35 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_IN (ICE US Index Futures) | 2016-03-17 17:15:35 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2016-03-17 17:15:35 Supported exchange: CME_Ho (CME Housing Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_INOp (ICE US Index Options) | 2016-03-17 17:15:35 Supported exchange: CME_AgOp (CME Agricultural Options) | 2016-03-17 17:15:35 Supported exchange: CME_In (CME Interest Rate Futures) | 2016-03-17 17:15:35 Supported exchange: E_CUR (Eurex Currency Futures) | 2016-03-17 17:15:35 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2016-03-17 17:15:35 Supported exchange: CME_CO (COMEX Futures) | 2016-03-17 17:15:35 Supported exchange: CME_Ag (CME Agricultural Futures) | 2016-03-17 17:15:35 Supported exchange: CME_EOp (CBOT Equity Options) | 2016-03-17 17:15:35 Supported exchange: CME_C (CBOT Commodity Futures) | 2016-03-17 17:15:35 Supported exchange: CME_F (CBOT Financial Futures) | 2016-03-17 17:15:35 Supported exchange: CME_E (CBOT Equity Futures) | 2016-03-17 17:15:35 Supported exchange: CME_K (KCBT Futures) | 2016-03-17 17:15:35 Supported exchange: CME_O (MGEX Futures) | 2016-03-17 17:15:35 Supported exchange: CME_FOp (CBOT Financial Options) | 2016-03-17 17:15:35 Supported exchange: ICE_MOp (ICE US Metals Options) | 2016-03-17 17:15:35 Supported exchange: E_INX (Eurex Index Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_M (ICE US Metals Futures) | 2016-03-17 17:15:35 Supported exchange: CME_OOp (MGEX Options) | 2016-03-17 17:15:35 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2016-03-17 17:15:35 Supported exchange: ICE_CU (ICE US Currency Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2016-03-17 17:15:35 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2016-03-17 17:15:35 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2016-03-17 17:15:35 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_F (ICE EU Financial Futures) | 2016-03-17 17:15:35 SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-03-17 17:15:35 SC Data - All Services | Sending logon request message. | 2016-03-17 17:15:35 Socket (319) | Connected. | 2016-03-17 17:15:35 HD Request # 30 | Sending historical data logon request message. | 2016-03-17 17:15:35 CTS FIX Historical Data socket (320) | Connected. | 2016-03-17 17:15:35 CTS FIX Historical Data socket (320) | Starting TLS 1.0 connection. | 2016-03-17 17:15:35 CTS FIX Historical Data socket (320) | Ignored Write event based on current socket state. | 2016-03-17 17:15:35 Mapping HO.20160500.CME_NY to HOK16. Service code: nymex | 2016-03-17 17:15:35 Mapping HO.20160500.CME_NY-baavg to HOK16. Service code: nymex | 2016-03-17 17:15:35 Supporting real-time market data updates for child symbol: HO.20160500.CME_NY-baavg | 2016-03-17 17:15:35 SC Data - All Services | Starting real-time market data updates for: HOK16. ID: 13 | 2016-03-17 17:15:35 Intraday data recording state for symbol HO.20160500.CME_NY-baavg is set to download 'Pending'. | 2016-03-17 17:15:35 Starting updates for: G.20160600.ICE_IC-baavg | 2016-03-17 17:15:35 Mapping G.20160600.ICE_IC-baavg to LFM16. Service code: ice.eu | 2016-03-17 17:15:35 Intraday data recording state for symbol G.20160600.ICE_IC-baavg is set to download 'Pending'. | 2016-03-17 17:15:35 CTS T4 FIX | Starting real-time market data updates for: FESX.20160300.E_INX. ID: 16 | 2016-03-17 17:15:35 CTS T4 FIX | Using primary service for historical data for FESX.20160300.E_INX | 2016-03-17 17:15:35 Intraday data recording state for symbol FESX.20160300.E_INX is set to download 'Pending'. | 2016-03-17 17:15:35 Supported exchange: CME_NYOp (NYMEX Options) | 2016-03-17 17:15:35 Supported exchange: CME_We (CME Weather Futures) | 2016-03-17 17:15:35 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2016-03-17 17:15:35 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_W (ICE Canada Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2016-03-17 17:15:35 Supported exchange: E_CUROp (Eurex Currency Options) | 2016-03-17 17:15:35 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2016-03-17 17:15:35 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2016-03-17 17:15:35 Supported exchange: CME_COOp (COMEX Options) | 2016-03-17 17:15:35 Supported exchange: LME_ME (LME Metal Futures) | 2016-03-17 17:15:35 Supported exchange: LME_PL (LME Plastic Futures) | 2016-03-17 17:15:35 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2016-03-17 17:15:35 Supported exchange: CME_InOp (CME Interest Rate Options) | 2016-03-17 17:15:35 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2016-03-17 17:15:35 Supported exchange: CME_Eq (CME Equity Futures) | 2016-03-17 17:15:35 Supported exchange: CBOE_CFE (CFE) | 2016-03-17 17:15:35 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2016-03-17 17:15:35 Supported exchange: CME_NY (NYMEX Futures) | 2016-03-17 17:15:35 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2016-03-17 17:15:35 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2016-03-17 17:15:35 Supported exchange: LME_IN (LME Index Futures) | 2016-03-17 17:15:35 HD Request # 30 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:15:22. Record interval: 0. Symbol: LFJ16-BAAVG | 2016-03-17 17:15:35 SC Data - All Services | Received logon response. | 2016-03-17 17:15:35 SC Data - All Services | Server Name: SC Real-Time Server. | 2016-03-17 17:15:35 SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-03-17 17:15:35 SC Data - All Services | Successfully connected. | 2016-03-17 17:15:35 SC Data - All Services | Restarting real-time data updates for symbol: G.20160400.ICE_IC -> LFJ16 | 2016-03-17 17:15:35 SC Data - All Services | Restarting real-time data updates for symbol: G.20160500.ICE_IC -> LFK16 | 2016-03-17 17:15:35 SC Data - All Services | Restarting real-time data updates for symbol: G.20160600.ICE_IC -> LFM16 | 2016-03-17 17:15:35 SC Data - All Services | Restarting real-time data updates for symbol: HO.20160400.CME_NY -> HOJ16 | 2016-03-17 17:15:35 SC Data - All Services | Restarting real-time data updates for symbol: HO.20160500.CME_NY -> HOK16 | 2016-03-17 17:15:35 SC Data - All Services | Restarting real-time data updates for symbol: HO.20160600.CME_NY -> HOM16 | 2016-03-17 17:15:35 Socket (319) | Shutdown and closed. | 2016-03-17 17:15:35 The network socket for historical data has been closed. | 2016-03-17 17:15:35 HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:35 HD Request # 30 | Intraday download COMPLETE for G.20160400.ICE_IC-baavg. Completion time: 1s. Unique request ID: 29 | 2016-03-17 17:15:35 Removed historical data download ID 29 | 2016-03-17 17:15:35 Real-time Intraday chart data file updates started for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:35 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\G.20160400.ICE_IC-baavg.scid | 2016-03-17 17:15:35 Intraday chart data file opened for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:35 HD Request # 32 | Downloading Intraday chart data for G.20160600.ICE_IC to the file G.20160600.ICE_IC.scid. Service: ice.eu | 2016-03-17 17:15:35 HD Request # 32 | Download start Date-Time: 2016-03-17 17:14:35.000 | 2016-03-17 17:15:35 HD Request # 32 | Using server: scdf1.sierracharts.com port 10149 | 2016-03-17 17:15:35 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-03-17 17:15:35 G.20160400.ICE_IC-baavg [M] Weekly #9 | Reloading chart. | 2016-03-17 17:15:35 CTS T4 FIX | Using primary service for historical data for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:35 Socket (321) | Connected. | 2016-03-17 17:15:35 HD Request # 32 | Sending historical data logon request message. | 2016-03-17 17:15:35 HD Request # 32 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:14:35. Record interval: 0. Symbol: LFM16 | 2016-03-17 17:15:35 CTS FIX Historical Data socket (320) | SSL connection established. | 2016-03-17 17:15:35 G.20160400.ICE_IC-baavg [M] Daily #7 | Reloading chart. | 2016-03-17 17:15:35 CTS T4 FIX | Using primary service for historical data for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:35 HD Request # 32 | Decompressing data. | 2016-03-17 17:15:35 HD Request # 32 | Receiving Intraday data for G.20160600.ICE_IC starting at 2016-03-17 17:14:35 | 2016-03-17 17:15:35 Socket (321) | Shutdown and closed. | 2016-03-17 17:15:35 The network socket for historical data has been closed. | 2016-03-17 17:15:35 HD Request # 32 | Received 6 records from 2016-03-17 17:14:35 to 2016-03-17 17:14:35 (0.0 seconds) and wrote 0 records for G.20160600.ICE_IC | 2016-03-17 17:15:35 HD Request # 32 | Intraday download COMPLETE for G.20160600.ICE_IC. Completion time: 0s. Unique request ID: 31 | 2016-03-17 17:15:35 Removed historical data download ID 31 | 2016-03-17 17:15:35 Real-time Intraday chart data file updates started for G.20160600.ICE_IC | 2016-03-17 17:15:35 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\G.20160600.ICE_IC.scid | 2016-03-17 17:15:35 Intraday chart data file opened for G.20160600.ICE_IC | 2016-03-17 17:15:35 HD Request # 33 | Downloading Intraday chart data for G.20160400.ICE_IC to the file G.20160400.ICE_IC.scid. Service: ice.eu | 2016-03-17 17:15:35 HD Request # 33 | Download start Date-Time: 2016-03-17 17:14:35.000 | 2016-03-17 17:15:35 HD Request # 33 | Using server: scdf2.sierracharts.com port 10149 | 2016-03-17 17:15:35 G.20160400.ICE_IC-baavg [M] Daily #2 | Reloading chart. | 2016-03-17 17:15:35 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-03-17 17:15:35 CTS T4 FIX | Using primary service for historical data for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:35 G.20160400.ICE_IC-baavg [M] Weekly #3 | Reloading chart. | 2016-03-17 17:15:35 CTS T4 FIX | Using primary service for historical data for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:35 Socket (322) | Connected. | 2016-03-17 17:15:35 HD Request # 33 | Sending historical data logon request message. | 2016-03-17 17:15:35 G.20160400.ICE_IC-baavg [M] Weekly #19 | Reloading chart. | 2016-03-17 17:15:35 CTS T4 FIX | Using primary service for historical data for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:35 Chart #8 has tagged chart #6 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:36 CTS T4 FIX | Sending security definition request for symbol FDAX.20160300.E_INX | 2016-03-17 17:15:36 G.20160400.ICE_IC-baavg [M] Weekly #17 | Reloading chart. | 2016-03-17 17:15:36 CTS T4 FIX | Using primary service for historical data for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:36 G.20160400.ICE_IC-baavg [M] Daily #1 | Reloading chart. | 2016-03-17 17:15:36 CTS T4 FIX | Using primary service for historical data for G.20160400.ICE_IC-baavg | 2016-03-17 17:15:36 HD Request # 33 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:14:35. Record interval: 0. Symbol: LFJ16 | 2016-03-17 17:15:36 CTS FIX Historical Data: Sending the Logon message. | 2016-03-17 17:15:36 CTS T4 FIX | Received matching security definition for symbol FDAX.20160300.E_INX. Subscribing to data. | 2016-03-17 17:15:36 CTS T4 FIX | Received 1 security definitions for underlying symbol FDAX | 2016-03-17 17:15:36 HD Request # 33 | Decompressing data. | 2016-03-17 17:15:36 HD Request # 33 | Receiving Intraday data for G.20160400.ICE_IC starting at 2016-03-17 17:14:35 | 2016-03-17 17:15:36 Socket (322) | Shutdown and closed. | 2016-03-17 17:15:36 The network socket for historical data has been closed. | 2016-03-17 17:15:36 HD Request # 33 | Received 13 records from 2016-03-17 17:14:35 to 2016-03-17 17:14:35 (0.0 seconds) and wrote 0 records for G.20160400.ICE_IC | 2016-03-17 17:15:36 HD Request # 33 | Intraday download COMPLETE for G.20160400.ICE_IC. Completion time: 1s. Unique request ID: 33 | 2016-03-17 17:15:36 Removed historical data download ID 33 | 2016-03-17 17:15:36 Real-time Intraday chart data file updates started for G.20160400.ICE_IC | 2016-03-17 17:15:36 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\G.20160400.ICE_IC.scid | 2016-03-17 17:15:36 Intraday chart data file opened for G.20160400.ICE_IC | 2016-03-17 17:15:36 HD Request # 34 | Downloading Intraday chart data for G.20160500.ICE_IC to the file G.20160500.ICE_IC.scid. Service: ice.eu | 2016-03-17 17:15:36 HD Request # 34 | Download start Date-Time: 2016-03-17 17:14:53.000 | 2016-03-17 17:15:36 HD Request # 34 | Using server: scdf1.sierracharts.com port 10149 | 2016-03-17 17:15:36 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-03-17 17:15:36 Socket (323) | Connected. | 2016-03-17 17:15:36 HD Request # 34 | Sending historical data logon request message. | 2016-03-17 17:15:36 CTS FIX Historical Data: Connected to Historical data server. | 2016-03-17 17:15:36 HD Request # 31 | Requesting historical Tick data for FDAX.20160300.E_INX from 2016-03-17 00:00:00 to 2016-03-17 00:00:00 (US Central Time). | 2016-03-17 17:15:36 HO.20160400.CME_NY-baavg/HO.20160400.CME_NY [M] 10 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:36 HD Request # 34 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:14:53. Record interval: 0. Symbol: LFK16 | 2016-03-17 17:15:36 HD Request # 34 | Decompressing data. | 2016-03-17 17:15:36 HD Request # 34 | Receiving Intraday data for G.20160500.ICE_IC starting at 2016-03-17 17:14:53 | 2016-03-17 17:15:36 Socket (323) | Shutdown and closed. | 2016-03-17 17:15:36 The network socket for historical data has been closed. | 2016-03-17 17:15:36 Chart #6 has tagged chart #15 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:36 Chart #6 has tagged chart #2 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:36 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:36 HD Request # 34 | Received 1 record from 2016-03-17 17:14:53 to 2016-03-17 17:14:53 (0.0 seconds) and wrote 0 records for G.20160500.ICE_IC | 2016-03-17 17:15:36 HD Request # 34 | Intraday download COMPLETE for G.20160500.ICE_IC. Completion time: 0s. Unique request ID: 34 | 2016-03-17 17:15:36 Removed historical data download ID 34 | 2016-03-17 17:15:36 Real-time Intraday chart data file updates started for G.20160500.ICE_IC | 2016-03-17 17:15:36 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\G.20160500.ICE_IC.scid | 2016-03-17 17:15:36 Intraday chart data file opened for G.20160500.ICE_IC | 2016-03-17 17:15:36 HD Request # 35 | Downloading Intraday chart data for HO.20160400.CME_NY-baavg to the file HO.20160400.CME_NY-baavg.scid. Service: nymex | 2016-03-17 17:15:36 HD Request # 35 | Download start Date-Time: 2016-03-17 17:15:22.000 | 2016-03-17 17:15:36 HD Request # 35 | Using server: scdf2.sierracharts.com port 10149 | 2016-03-17 17:15:36 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-03-17 17:15:36 G.20160400.ICE_IC-baavg [M] 120 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:36 G.20160400.ICE_IC-baavg [M] Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:36 G.20160400.ICE_IC-baavg [M] Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:36 CTS T4 FIX | Sending security definition request for symbol FESX.20160300.E_INX | 2016-03-17 17:15:37 Socket (324) | Connected. | 2016-03-17 17:15:37 HD Request # 35 | Sending historical data logon request message. | 2016-03-17 17:15:37 CTS T4 FIX | Received matching security definition for symbol FESX.20160300.E_INX. Subscribing to data. | 2016-03-17 17:15:37 CTS T4 FIX | Received 1 security definitions for underlying symbol FESX | 2016-03-17 17:15:37 HD Request # 35 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:15:22. Record interval: 0. Symbol: HOJ16-BAAVG | 2016-03-17 17:15:37 HD Request # 35 | Decompressing data. | 2016-03-17 17:15:37 HD Request # 35 | Receiving Intraday data for HO.20160400.CME_NY-baavg starting at 2016-03-17 17:15:32 | 2016-03-17 17:15:37 HD Request # 35 | Timestamp of first Intraday data file record written: 2016-03-17 17:15:32 | 2016-03-17 17:15:37 Socket (324) | Shutdown and closed. | 2016-03-17 17:15:37 The network socket for historical data has been closed. | 2016-03-17 17:15:37 HD Request # 35 | Received 1 record from 2016-03-17 17:15:32 to 2016-03-17 17:15:32 (0.0 seconds) and wrote 1 record for HO.20160400.CME_NY-baavg | 2016-03-17 17:15:37 HD Request # 35 | Intraday download COMPLETE for HO.20160400.CME_NY-baavg. Completion time: 0s. Unique request ID: 35 | 2016-03-17 17:15:37 Removed historical data download ID 35 | 2016-03-17 17:15:37 Real-time Intraday chart data file updates started for HO.20160400.CME_NY-baavg | 2016-03-17 17:15:37 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\HO.20160400.CME_NY-baavg.scid | 2016-03-17 17:15:37 Intraday chart data file opened for HO.20160400.CME_NY-baavg | 2016-03-17 17:15:37 HD Request # 36 | Downloading Intraday chart data for HO.20160600.CME_NY-baavg to the file HO.20160600.CME_NY-baavg.scid. Service: nymex | 2016-03-17 17:15:37 HD Request # 36 | Download start Date-Time: 2016-03-17 17:15:11.000 | 2016-03-17 17:15:37 HD Request # 36 | Using server: scdf1.sierracharts.com port 10149 | 2016-03-17 17:15:37 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-03-17 17:15:37 Socket (325) | Connected. | 2016-03-17 17:15:37 HD Request # 36 | Sending historical data logon request message. | 2016-03-17 17:15:37 Chart #6 has tagged chart #15 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 Chart #6 has tagged chart #2 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 G.20160400.ICE_IC-baavg [M] Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 HD Request # 36 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:15:11. Record interval: 0. Symbol: HOM16-BAAVG | 2016-03-17 17:15:37 Socket (325) | Shutdown and closed. | 2016-03-17 17:15:37 The network socket for historical data has been closed. | 2016-03-17 17:15:37 HD Request # 36 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HO.20160600.CME_NY-baavg | 2016-03-17 17:15:37 HD Request # 36 | Intraday download COMPLETE for HO.20160600.CME_NY-baavg. Completion time: 0s. Unique request ID: 36 | 2016-03-17 17:15:37 Removed historical data download ID 36 | 2016-03-17 17:15:37 Real-time Intraday chart data file updates started for HO.20160600.CME_NY-baavg | 2016-03-17 17:15:37 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\HO.20160600.CME_NY-baavg.scid | 2016-03-17 17:15:37 Intraday chart data file opened for HO.20160600.CME_NY-baavg | 2016-03-17 17:15:37 HD Request # 37 | Downloading Intraday chart data for G.20160500.ICE_IC-baavg to the file G.20160500.ICE_IC-baavg.scid. Service: ice.eu | 2016-03-17 17:15:37 HD Request # 37 | Download start Date-Time: 2016-03-17 17:15:22.000 | 2016-03-17 17:15:37 HD Request # 37 | Using server: scdf2.sierracharts.com port 10149 | 2016-03-17 17:15:37 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-03-17 17:15:37 Socket (326) | Connected. | 2016-03-17 17:15:37 HD Request # 37 | Sending historical data logon request message. | 2016-03-17 17:15:37 HD Request # 37 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:15:22. Record interval: 0. Symbol: LFK16-BAAVG | 2016-03-17 17:15:37 G.20160400.ICE_IC-baavg [M] Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 Chart #13 has tagged chart #16 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 Chart #13 has tagged chart #7 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 G.20160400.ICE_IC-baavg [M] 120 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:37 Socket (326) | Shutdown and closed. | 2016-03-17 17:15:38 The network socket for historical data has been closed. | 2016-03-17 17:15:38 HD Request # 37 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for G.20160500.ICE_IC-baavg | 2016-03-17 17:15:38 HD Request # 37 | Receiving Intraday data for G.20160500.ICE_IC-baavg starting at 2016-03-17 17:15:32 | 2016-03-17 17:15:38 HD Request # 37 | Timestamp of first Intraday data file record written: 2016-03-17 17:15:32 | 2016-03-17 17:15:38 Added 33 Time and Sales records to Intraday data file for G.20160500.ICE_IC-baavg after download. | 2016-03-17 17:15:38 HD Request # 37 | Intraday download COMPLETE for G.20160500.ICE_IC-baavg. Completion time: 0s. Unique request ID: 37 | 2016-03-17 17:15:38 Removed historical data download ID 37 | 2016-03-17 17:15:38 Real-time Intraday chart data file updates started for G.20160500.ICE_IC-baavg | 2016-03-17 17:15:38 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\G.20160500.ICE_IC-baavg.scid | 2016-03-17 17:15:38 Intraday chart data file opened for G.20160500.ICE_IC-baavg | 2016-03-17 17:15:38 HD Request # 38 | Downloading Intraday chart data for HO.20160500.CME_NY-baavg to the file HO.20160500.CME_NY-baavg.scid. Service: nymex | 2016-03-17 17:15:38 HD Request # 38 | Download start Date-Time: 2016-03-17 17:15:17.000 | 2016-03-17 17:15:38 HD Request # 38 | Using server: scdf1.sierracharts.com port 10149 | 2016-03-17 17:15:38 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] Weekly #17 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Socket (327) | Connected. | 2016-03-17 17:15:38 HD Request # 38 | Sending historical data logon request message. | 2016-03-17 17:15:38 HD Request # 38 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:15:17. Record interval: 0. Symbol: HOK16-BAAVG | 2016-03-17 17:15:38 HD Request # 31 | Receiving Intraday data for FDAX.20160300.E_INX starting at 2016-03-17 07:00:03 | 2016-03-17 17:15:38 Socket (327) | Shutdown and closed. | 2016-03-17 17:15:38 The network socket for historical data has been closed. | 2016-03-17 17:15:38 HD Request # 31 | Timestamp of first Intraday data file record written: 2016-03-17 17:15:26 | 2016-03-17 17:15:38 HD Request # 31 | Total records received: 54505 | 2016-03-17 17:15:38 HD Request # 31 | Requesting historical Tick data for FDAX.20160300.E_INX from 2016-03-18 00:00:00 to 2016-03-18 00:00:00 (US Central Time). | 2016-03-17 17:15:38 HD Request # 38 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HO.20160500.CME_NY-baavg | 2016-03-17 17:15:38 HD Request # 38 | Receiving Intraday data for HO.20160500.CME_NY-baavg starting at 2016-03-17 17:15:32 | 2016-03-17 17:15:38 HD Request # 38 | Timestamp of first Intraday data file record written: 2016-03-17 17:15:32 | 2016-03-17 17:15:38 Added 2 Time and Sales records to Intraday data file for HO.20160500.CME_NY-baavg after download. | 2016-03-17 17:15:38 HD Request # 38 | Intraday download COMPLETE for HO.20160500.CME_NY-baavg. Completion time: 1s. Unique request ID: 39 | 2016-03-17 17:15:38 Removed historical data download ID 39 | 2016-03-17 17:15:38 Real-time Intraday chart data file updates started for HO.20160500.CME_NY-baavg | 2016-03-17 17:15:38 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\HO.20160500.CME_NY-baavg.scid | 2016-03-17 17:15:38 Intraday chart data file opened for HO.20160500.CME_NY-baavg | 2016-03-17 17:15:38 HD Request # 39 | Downloading Intraday chart data for G.20160600.ICE_IC-baavg to the file G.20160600.ICE_IC-baavg.scid. Service: ice.eu | 2016-03-17 17:15:38 HD Request # 39 | Download start Date-Time: 2016-03-17 17:15:22.000 | 2016-03-17 17:15:38 HD Request # 39 | Using server: scdf2.sierracharts.com port 10149 | 2016-03-17 17:15:38 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-03-17 17:15:38 Chart #5 has tagged chart #1 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #5 has tagged chart #11 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #5 has tagged chart #19 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #5 has tagged chart #3 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] 120 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] Daily #7 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] Weekly #3 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #4 has tagged chart #5 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] 120 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 HD Request # 31 | Total records received: 54505 | 2016-03-17 17:15:38 HD Request # 31 | Requesting historical Tick data for FDAX.20160300.E_INX from 2016-03-19 00:00:00 to 2016-03-19 00:00:00 (US Central Time). | 2016-03-17 17:15:38 CTS T4 FIX | Sending security definition request for symbol FGBL.20160600.E_BND | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] Weekly #19 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Socket (328) | Connected. | 2016-03-17 17:15:38 HD Request # 39 | Sending historical data logon request message. | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] Daily #1 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 CTS T4 FIX | Received matching security definition for symbol FGBL.20160600.E_BND. Subscribing to data. | 2016-03-17 17:15:38 CTS T4 FIX | Received 1 security definitions for underlying symbol FGBL | 2016-03-17 17:15:38 HD Request # 31 | Received 54505 records from 2016-03-17 07:00:03 to 2016-03-17 17:15:32 (10.3 hours) and wrote 12 records for FDAX.20160300.E_INX | 2016-03-17 17:15:38 Added 2 Time and Sales records to Intraday data file for FDAX.20160300.E_INX after download. | 2016-03-17 17:15:38 HD Request # 31 | Intraday download COMPLETE for FDAX.20160300.E_INX. Completion time: 4s. Unique request ID: 30 | 2016-03-17 17:15:38 Removed historical data download ID 30 | 2016-03-17 17:15:38 Real-time Intraday chart data file updates started for FDAX.20160300.E_INX | 2016-03-17 17:15:38 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\FDAX.20160300.E_INX.scid | 2016-03-17 17:15:38 Intraday chart data file opened for FDAX.20160300.E_INX | 2016-03-17 17:15:38 HD Request # 39 | Requesting Intraday data. Start Date-Time: 2016-03-17 17:15:22. Record interval: 0. Symbol: LFM16-BAAVG | 2016-03-17 17:15:38 HD Request # 40 | Downloading Intraday chart data for FGBL.20160600.E_BND to the file FGBL.20160600.E_BND.scid. Service: cts | 2016-03-17 17:15:38 HD Request # 40 | Download start Date-Time: 2016-03-17 17:15:21.000 | 2016-03-17 17:15:38 HD Request # 40 | Requesting historical Tick data for FGBL.20160600.E_BND from 2016-03-17 00:00:00 to 2016-03-17 00:00:00 (US Central Time). | 2016-03-17 17:15:38 HO.20160500.CME_NY-baavg [M] 10 Sec #5 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Socket (328) | Shutdown and closed. | 2016-03-17 17:15:38 The network socket for historical data has been closed. | 2016-03-17 17:15:38 Chart #5 has tagged chart #1 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #5 has tagged chart #11 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #5 has tagged chart #19 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #5 has tagged chart #3 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 HD Request # 39 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for G.20160600.ICE_IC-baavg | 2016-03-17 17:15:38 HD Request # 39 | Receiving Intraday data for G.20160600.ICE_IC-baavg starting at 2016-03-17 17:15:32 | 2016-03-17 17:15:38 HD Request # 39 | Timestamp of first Intraday data file record written: 2016-03-17 17:15:32 | 2016-03-17 17:15:38 Added 34 Time and Sales records to Intraday data file for G.20160600.ICE_IC-baavg after download. | 2016-03-17 17:15:38 HD Request # 39 | Intraday download COMPLETE for G.20160600.ICE_IC-baavg. Completion time: 0s. Unique request ID: 40 | 2016-03-17 17:15:38 Removed historical data download ID 40 | 2016-03-17 17:15:38 Real-time Intraday chart data file updates started for G.20160600.ICE_IC-baavg | 2016-03-17 17:15:38 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\G.20160600.ICE_IC-baavg.scid | 2016-03-17 17:15:38 Intraday chart data file opened for G.20160600.ICE_IC-baavg | 2016-03-17 17:15:38 CTS FIX: Received 'Account Update/Balance Data' collateral report. | 2016-03-17 17:15:38 Chart #10 has tagged chart #13 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] Weekly #3 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 HO.20160600.CME_NY-baavg/HO.20160600.CME_NY [M] 10 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #13 has tagged chart #16 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #13 has tagged chart #17 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 Chart #13 has tagged chart #7 for full recalculation. Chartbook: Dist Arb.cht | 2016-03-17 17:15:38 G.20160400.ICE_IC-baavg [M] 120 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:39 HD Request # 40 | Receiving Intraday data for FGBL.20160600.E_BND starting at 2016-03-17 07:01:06 | 2016-03-17 17:15:39 HD Request # 40 | Timestamp of first Intraday data file record written: 2016-03-17 17:15:26 | 2016-03-17 17:15:39 HD Request # 40 | Total records received: 50895 | 2016-03-17 17:15:39 HD Request # 40 | Requesting historical Tick data for FGBL.20160600.E_BND from 2016-03-18 00:00:00 to 2016-03-18 00:00:00 (US Central Time). | 2016-03-17 17:15:39 G.20160400.ICE_IC-baavg [M] Weekly #19 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:39 G.20160400.ICE_IC-baavg [M] Weekly #17 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:39 G.20160400.ICE_IC-baavg [M] Daily #1 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:39 G.20160400.ICE_IC-baavg [M] 120 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:39 G.20160400.ICE_IC-baavg [M] Daily #7 | Performing a full recalculation because it has been tagged. Chartbook: Dist Arb.cht | 2016-03-17 17:15:39 CTS FIX: Requesting Open Orders for account: 36* | 2016-03-17 17:15:39 HD Request # 40 | Total records received: 50895 | 2016-03-17 17:15:39 HD Request # 40 | Requesting historical Tick data for FGBL.20160600.E_BND from 2016-03-19 00:00:00 to 2016-03-19 00:00:00 (US Central Time). | 2016-03-17 17:15:39 CTS T4 FIX | Sending security definition request for symbol FGBX.20160600.E_BND | 2016-03-17 17:15:40 CTS FIX: Received Account List collateral report. | 2016-03-17 17:15:40 HD Request # 40 | Received 50895 records from 2016-03-17 07:01:06 to 2016-03-17 17:15:33 (10.2 hours) and wrote 3 records for FGBL.20160600.E_BND | 2016-03-17 17:15:40 HD Request # 40 | Intraday download COMPLETE for FGBL.20160600.E_BND. Completion time: 0s. Unique request ID: 32 | 2016-03-17 17:15:40 Removed historical data download ID 32 | 2016-03-17 17:15:40 Real-time Intraday chart data file updates started for FGBL.20160600.E_BND | 2016-03-17 17:15:40 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\FGBL.20160600.E_BND.scid | 2016-03-17 17:15:40 Intraday chart data file opened for FGBL.20160600.E_BND | 2016-03-17 17:15:40 HD Request # 41 | Downloading Intraday chart data for FGBX.20160600.E_BND to the file FGBX.20160600.E_BND.scid. Service: cts | 2016-03-17 17:15:40 HD Request # 41 | Download start Date-Time: 2016-03-17 17:14:54.000 | 2016-03-17 17:15:40 CTS T4 FIX | Received matching security definition for symbol FGBX.20160600.E_BND. Subscribing to data. | 2016-03-17 17:15:40 CTS T4 FIX | Received matching security definition for symbol FGBX.20160600.E_BND. Requesting historical data. | 2016-03-17 17:15:40 HD Request # 41 | Requesting historical Tick data for FGBX.20160600.E_BND from 2016-03-17 00:00:00 to 2016-03-17 00:00:00 (US Central Time). | 2016-03-17 17:15:40 CTS T4 FIX | Received 1 security definitions for underlying symbol FGBX | 2016-03-17 17:15:40 HD Request # 41 | Receiving Intraday data for FGBX.20160600.E_BND starting at 2016-03-17 07:01:06 | 2016-03-17 17:15:40 HD Request # 41 | Timestamp of first Intraday data file record written: 2016-03-17 17:15:32 | 2016-03-17 17:15:40 HD Request # 41 | Total records received: 13535 | 2016-03-17 17:15:40 HD Request # 41 | Requesting historical Tick data for FGBX.20160600.E_BND from 2016-03-18 00:00:00 to 2016-03-18 00:00:00 (US Central Time). | 2016-03-17 17:15:40 HD Request # 41 | Total records received: 13535 | 2016-03-17 17:15:40 HD Request # 41 | Requesting historical Tick data for FGBX.20160600.E_BND from 2016-03-19 00:00:00 to 2016-03-19 00:00:00 (US Central Time). | 2016-03-17 17:15:40 HD Request # 41 | Received 13535 records from 2016-03-17 07:01:06 to 2016-03-17 17:15:32 (10.2 hours) and wrote 1 record for FGBX.20160600.E_BND | 2016-03-17 17:15:40 HD Request # 41 | Intraday download COMPLETE for FGBX.20160600.E_BND. Completion time: 1s. Unique request ID: 38 | 2016-03-17 17:15:40 Removed historical data download ID 38 | 2016-03-17 17:15:40 Real-time Intraday chart data file updates started for FGBX.20160600.E_BND | 2016-03-17 17:15:40 Opened cached Intraday file: C:\Users\capitaleast\Documents\New folder\SC2\FGBX.20160600.E_BND.scid | 2016-03-17 17:15:40 Intraday chart data file opened for FGBX.20160600.E_BND | 2016-03-17 17:15:40 HD Request # 42 | Downloading Intraday chart data for FESX.20160300.E_INX to the file FESX.20160300.E_INX.scid. Service: cts | 2016-03-17 17:15:40 HD Request # 42 | Download start Date-Time: 2013-06-21 18:15:40.000 | 2016-03-17 17:15:40 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-21 00:00:00 to 2013-06-21 00:00:00 (US Central Time). | 2016-03-17 17:15:40 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:40 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-22 00:00:00 to 2013-06-22 00:00:00 (US Central Time). | 2016-03-17 17:15:40 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-23 00:00:00 to 2013-06-23 00:00:00 (US Central Time). | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-24 00:00:00 to 2013-06-24 00:00:00 (US Central Time). | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-25 00:00:00 to 2013-06-25 00:00:00 (US Central Time). | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-26 00:00:00 to 2013-06-26 00:00:00 (US Central Time). | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-27 00:00:00 to 2013-06-27 00:00:00 (US Central Time). | 2016-03-17 17:15:41 CTS T4 FIX | Sending security definition request for symbol G.20160400.ICE_IC | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-28 00:00:00 to 2013-06-28 00:00:00 (US Central Time). | 2016-03-17 17:15:41 CTS T4 FIX | Received 1 security definitions for underlying symbol G | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-29 00:00:00 to 2013-06-29 00:00:00 (US Central Time). | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-06-30 00:00:00 to 2013-06-30 00:00:00 (US Central Time). | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:41 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-01 00:00:00 to 2013-07-01 00:00:00 (US Central Time). | 2016-03-17 17:15:41 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-02 00:00:00 to 2013-07-02 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-03 00:00:00 to 2013-07-03 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-04 00:00:00 to 2013-07-04 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-05 00:00:00 to 2013-07-05 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-06 00:00:00 to 2013-07-06 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-07 00:00:00 to 2013-07-07 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-08 00:00:00 to 2013-07-08 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-09 00:00:00 to 2013-07-09 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:42 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-10 00:00:00 to 2013-07-10 00:00:00 (US Central Time). | 2016-03-17 17:15:42 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-11 00:00:00 to 2013-07-11 00:00:00 (US Central Time). | 2016-03-17 17:15:43 CTS T4 FIX | Sending security definition request for symbol G.20160500.ICE_IC | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-12 00:00:00 to 2013-07-12 00:00:00 (US Central Time). | 2016-03-17 17:15:43 CTS T4 FIX | Received 1 security definitions for underlying symbol G | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-13 00:00:00 to 2013-07-13 00:00:00 (US Central Time). | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-14 00:00:00 to 2013-07-14 00:00:00 (US Central Time). | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-15 00:00:00 to 2013-07-15 00:00:00 (US Central Time). | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-16 00:00:00 to 2013-07-16 00:00:00 (US Central Time). | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-17 00:00:00 to 2013-07-17 00:00:00 (US Central Time). | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-18 00:00:00 to 2013-07-18 00:00:00 (US Central Time). | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-19 00:00:00 to 2013-07-19 00:00:00 (US Central Time). | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:43 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-20 00:00:00 to 2013-07-20 00:00:00 (US Central Time). | 2016-03-17 17:15:43 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-21 00:00:00 to 2013-07-21 00:00:00 (US Central Time). | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-22 00:00:00 to 2013-07-22 00:00:00 (US Central Time). | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-23 00:00:00 to 2013-07-23 00:00:00 (US Central Time). | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-24 00:00:00 to 2013-07-24 00:00:00 (US Central Time). | 2016-03-17 17:15:44 CTS T4 FIX | Sending security definition request for symbol G.20160600.ICE_IC | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-25 00:00:00 to 2013-07-25 00:00:00 (US Central Time). | 2016-03-17 17:15:44 CTS T4 FIX | Received 1 security definitions for underlying symbol G | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-26 00:00:00 to 2013-07-26 00:00:00 (US Central Time). | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-27 00:00:00 to 2013-07-27 00:00:00 (US Central Time). | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-28 00:00:00 to 2013-07-28 00:00:00 (US Central Time). | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:44 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-29 00:00:00 to 2013-07-29 00:00:00 (US Central Time). | 2016-03-17 17:15:44 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-30 00:00:00 to 2013-07-30 00:00:00 (US Central Time). | 2016-03-17 17:15:45 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-07-31 00:00:00 to 2013-07-31 00:00:00 (US Central Time). | 2016-03-17 17:15:45 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-01 00:00:00 to 2013-08-01 00:00:00 (US Central Time). | 2016-03-17 17:15:45 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-02 00:00:00 to 2013-08-02 00:00:00 (US Central Time). | 2016-03-17 17:15:45 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-03 00:00:00 to 2013-08-03 00:00:00 (US Central Time). | 2016-03-17 17:15:45 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-04 00:00:00 to 2013-08-04 00:00:00 (US Central Time). | 2016-03-17 17:15:45 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-05 00:00:00 to 2013-08-05 00:00:00 (US Central Time). | 2016-03-17 17:15:45 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-06 00:00:00 to 2013-08-06 00:00:00 (US Central Time). | 2016-03-17 17:15:45 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:45 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-07 00:00:00 to 2013-08-07 00:00:00 (US Central Time). | 2016-03-17 17:15:45 CTS T4 FIX | Sending security definition request for symbol HO.20160400.CME_NY | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-08 00:00:00 to 2013-08-08 00:00:00 (US Central Time). | 2016-03-17 17:15:46 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-09 00:00:00 to 2013-08-09 00:00:00 (US Central Time). | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-10 00:00:00 to 2013-08-10 00:00:00 (US Central Time). | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-11 00:00:00 to 2013-08-11 00:00:00 (US Central Time). | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-12 00:00:00 to 2013-08-12 00:00:00 (US Central Time). | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-13 00:00:00 to 2013-08-13 00:00:00 (US Central Time). | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-14 00:00:00 to 2013-08-14 00:00:00 (US Central Time). | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-15 00:00:00 to 2013-08-15 00:00:00 (US Central Time). | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:46 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-16 00:00:00 to 2013-08-16 00:00:00 (US Central Time). | 2016-03-17 17:15:46 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-17 00:00:00 to 2013-08-17 00:00:00 (US Central Time). | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-18 00:00:00 to 2013-08-18 00:00:00 (US Central Time). | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-19 00:00:00 to 2013-08-19 00:00:00 (US Central Time). | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-20 00:00:00 to 2013-08-20 00:00:00 (US Central Time). | 2016-03-17 17:15:47 CTS T4 FIX | Sending security definition request for symbol HO.20160500.CME_NY | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-21 00:00:00 to 2013-08-21 00:00:00 (US Central Time). | 2016-03-17 17:15:47 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-22 00:00:00 to 2013-08-22 00:00:00 (US Central Time). | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-23 00:00:00 to 2013-08-23 00:00:00 (US Central Time). | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-24 00:00:00 to 2013-08-24 00:00:00 (US Central Time). | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:47 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-25 00:00:00 to 2013-08-25 00:00:00 (US Central Time). | 2016-03-17 17:15:47 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-26 00:00:00 to 2013-08-26 00:00:00 (US Central Time). | 2016-03-17 17:15:48 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-27 00:00:00 to 2013-08-27 00:00:00 (US Central Time). | 2016-03-17 17:15:48 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-28 00:00:00 to 2013-08-28 00:00:00 (US Central Time). | 2016-03-17 17:15:48 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-29 00:00:00 to 2013-08-29 00:00:00 (US Central Time). | 2016-03-17 17:15:48 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-30 00:00:00 to 2013-08-30 00:00:00 (US Central Time). | 2016-03-17 17:15:48 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-08-31 00:00:00 to 2013-08-31 00:00:00 (US Central Time). | 2016-03-17 17:15:48 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-01 00:00:00 to 2013-09-01 00:00:00 (US Central Time). | 2016-03-17 17:15:48 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-02 00:00:00 to 2013-09-02 00:00:00 (US Central Time). | 2016-03-17 17:15:48 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:48 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-03 00:00:00 to 2013-09-03 00:00:00 (US Central Time). | 2016-03-17 17:15:48 CTS T4 FIX | Sending security definition request for symbol HO.20160600.CME_NY | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-04 00:00:00 to 2013-09-04 00:00:00 (US Central Time). | 2016-03-17 17:15:49 CTS T4 FIX | Received 1 security definitions for underlying symbol HO | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-05 00:00:00 to 2013-09-05 00:00:00 (US Central Time). | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-06 00:00:00 to 2013-09-06 00:00:00 (US Central Time). | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-07 00:00:00 to 2013-09-07 00:00:00 (US Central Time). | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-08 00:00:00 to 2013-09-08 00:00:00 (US Central Time). | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-09 00:00:00 to 2013-09-09 00:00:00 (US Central Time). | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-10 00:00:00 to 2013-09-10 00:00:00 (US Central Time). | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-11 00:00:00 to 2013-09-11 00:00:00 (US Central Time). | 2016-03-17 17:15:49 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:49 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-12 00:00:00 to 2013-09-12 00:00:00 (US Central Time). | 2016-03-17 17:15:49 CTS FIX: Received Account List collateral report. | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-13 00:00:00 to 2013-09-13 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-14 00:00:00 to 2013-09-14 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-15 00:00:00 to 2013-09-15 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-16 00:00:00 to 2013-09-16 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-17 00:00:00 to 2013-09-17 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-18 00:00:00 to 2013-09-18 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-19 00:00:00 to 2013-09-19 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-20 00:00:00 to 2013-09-20 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:50 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-21 00:00:00 to 2013-09-21 00:00:00 (US Central Time). | 2016-03-17 17:15:50 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-22 00:00:00 to 2013-09-22 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-23 00:00:00 to 2013-09-23 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-24 00:00:00 to 2013-09-24 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-25 00:00:00 to 2013-09-25 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-26 00:00:00 to 2013-09-26 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-27 00:00:00 to 2013-09-27 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-28 00:00:00 to 2013-09-28 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-29 00:00:00 to 2013-09-29 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:51 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-09-30 00:00:00 to 2013-09-30 00:00:00 (US Central Time). | 2016-03-17 17:15:51 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-01 00:00:00 to 2013-10-01 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-02 00:00:00 to 2013-10-02 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-03 00:00:00 to 2013-10-03 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-04 00:00:00 to 2013-10-04 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-05 00:00:00 to 2013-10-05 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-06 00:00:00 to 2013-10-06 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-07 00:00:00 to 2013-10-07 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-08 00:00:00 to 2013-10-08 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:52 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-09 00:00:00 to 2013-10-09 00:00:00 (US Central Time). | 2016-03-17 17:15:52 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-10 00:00:00 to 2013-10-10 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-11 00:00:00 to 2013-10-11 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-12 00:00:00 to 2013-10-12 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-13 00:00:00 to 2013-10-13 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-14 00:00:00 to 2013-10-14 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-15 00:00:00 to 2013-10-15 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-16 00:00:00 to 2013-10-16 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-17 00:00:00 to 2013-10-17 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:53 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-18 00:00:00 to 2013-10-18 00:00:00 (US Central Time). | 2016-03-17 17:15:53 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-19 00:00:00 to 2013-10-19 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-20 00:00:00 to 2013-10-20 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-21 00:00:00 to 2013-10-21 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-22 00:00:00 to 2013-10-22 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-23 00:00:00 to 2013-10-23 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-24 00:00:00 to 2013-10-24 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-25 00:00:00 to 2013-10-25 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-26 00:00:00 to 2013-10-26 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:54 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-27 00:00:00 to 2013-10-27 00:00:00 (US Central Time). | 2016-03-17 17:15:54 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-28 00:00:00 to 2013-10-28 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-29 00:00:00 to 2013-10-29 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-30 00:00:00 to 2013-10-30 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-10-31 00:00:00 to 2013-10-31 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-01 00:00:00 to 2013-11-01 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-02 00:00:00 to 2013-11-02 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-03 00:00:00 to 2013-11-03 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-04 00:00:00 to 2013-11-04 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:55 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-05 00:00:00 to 2013-11-05 00:00:00 (US Central Time). | 2016-03-17 17:15:55 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-06 00:00:00 to 2013-11-06 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-07 00:00:00 to 2013-11-07 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-08 00:00:00 to 2013-11-08 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-09 00:00:00 to 2013-11-09 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-10 00:00:00 to 2013-11-10 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-11 00:00:00 to 2013-11-11 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-12 00:00:00 to 2013-11-12 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-13 00:00:00 to 2013-11-13 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:56 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-14 00:00:00 to 2013-11-14 00:00:00 (US Central Time). | 2016-03-17 17:15:56 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-15 00:00:00 to 2013-11-15 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-16 00:00:00 to 2013-11-16 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-17 00:00:00 to 2013-11-17 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-18 00:00:00 to 2013-11-18 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-19 00:00:00 to 2013-11-19 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-20 00:00:00 to 2013-11-20 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-21 00:00:00 to 2013-11-21 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-22 00:00:00 to 2013-11-22 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-23 00:00:00 to 2013-11-23 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:57 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-24 00:00:00 to 2013-11-24 00:00:00 (US Central Time). | 2016-03-17 17:15:57 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-25 00:00:00 to 2013-11-25 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-26 00:00:00 to 2013-11-26 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-27 00:00:00 to 2013-11-27 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-28 00:00:00 to 2013-11-28 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-29 00:00:00 to 2013-11-29 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-11-30 00:00:00 to 2013-11-30 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-01 00:00:00 to 2013-12-01 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-02 00:00:00 to 2013-12-02 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:58 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-03 00:00:00 to 2013-12-03 00:00:00 (US Central Time). | 2016-03-17 17:15:58 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-04 00:00:00 to 2013-12-04 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-05 00:00:00 to 2013-12-05 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-06 00:00:00 to 2013-12-06 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-07 00:00:00 to 2013-12-07 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-08 00:00:00 to 2013-12-08 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-09 00:00:00 to 2013-12-09 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-10 00:00:00 to 2013-12-10 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-11 00:00:00 to 2013-12-11 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:15:59 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-12 00:00:00 to 2013-12-12 00:00:00 (US Central Time). | 2016-03-17 17:15:59 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-13 00:00:00 to 2013-12-13 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-14 00:00:00 to 2013-12-14 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-15 00:00:00 to 2013-12-15 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-16 00:00:00 to 2013-12-16 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-17 00:00:00 to 2013-12-17 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-18 00:00:00 to 2013-12-18 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-19 00:00:00 to 2013-12-19 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-20 00:00:00 to 2013-12-20 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:00 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-21 00:00:00 to 2013-12-21 00:00:00 (US Central Time). | 2016-03-17 17:16:00 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-22 00:00:00 to 2013-12-22 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-23 00:00:00 to 2013-12-23 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-24 00:00:00 to 2013-12-24 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-25 00:00:00 to 2013-12-25 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-26 00:00:00 to 2013-12-26 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-27 00:00:00 to 2013-12-27 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-28 00:00:00 to 2013-12-28 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-29 00:00:00 to 2013-12-29 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:01 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-30 00:00:00 to 2013-12-30 00:00:00 (US Central Time). | 2016-03-17 17:16:01 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2013-12-31 00:00:00 to 2013-12-31 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-01 00:00:00 to 2014-01-01 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-02 00:00:00 to 2014-01-02 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-03 00:00:00 to 2014-01-03 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-04 00:00:00 to 2014-01-04 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-05 00:00:00 to 2014-01-05 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-06 00:00:00 to 2014-01-06 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-07 00:00:00 to 2014-01-07 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:02 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-08 00:00:00 to 2014-01-08 00:00:00 (US Central Time). | 2016-03-17 17:16:02 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-09 00:00:00 to 2014-01-09 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-10 00:00:00 to 2014-01-10 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-11 00:00:00 to 2014-01-11 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-12 00:00:00 to 2014-01-12 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-13 00:00:00 to 2014-01-13 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-14 00:00:00 to 2014-01-14 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-15 00:00:00 to 2014-01-15 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-16 00:00:00 to 2014-01-16 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:03 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-17 00:00:00 to 2014-01-17 00:00:00 (US Central Time). | 2016-03-17 17:16:03 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-18 00:00:00 to 2014-01-18 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-19 00:00:00 to 2014-01-19 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-20 00:00:00 to 2014-01-20 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-21 00:00:00 to 2014-01-21 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-22 00:00:00 to 2014-01-22 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-23 00:00:00 to 2014-01-23 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-24 00:00:00 to 2014-01-24 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-25 00:00:00 to 2014-01-25 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:04 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-26 00:00:00 to 2014-01-26 00:00:00 (US Central Time). | 2016-03-17 17:16:04 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-27 00:00:00 to 2014-01-27 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-28 00:00:00 to 2014-01-28 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-29 00:00:00 to 2014-01-29 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-30 00:00:00 to 2014-01-30 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-01-31 00:00:00 to 2014-01-31 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-01 00:00:00 to 2014-02-01 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-02 00:00:00 to 2014-02-02 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-03 00:00:00 to 2014-02-03 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:05 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-04 00:00:00 to 2014-02-04 00:00:00 (US Central Time). | 2016-03-17 17:16:05 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:06 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-05 00:00:00 to 2014-02-05 00:00:00 (US Central Time). | 2016-03-17 17:16:06 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:06 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-06 00:00:00 to 2014-02-06 00:00:00 (US Central Time). | 2016-03-17 17:16:06 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:06 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-07 00:00:00 to 2014-02-07 00:00:00 (US Central Time). | 2016-03-17 17:16:06 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:06 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-08 00:00:00 to 2014-02-08 00:00:00 (US Central Time). | 2016-03-17 17:16:06 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:06 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-09 00:00:00 to 2014-02-09 00:00:00 (US Central Time). | 2016-03-17 17:16:06 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:06 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-10 00:00:00 to 2014-02-10 00:00:00 (US Central Time). | 2016-03-17 17:16:06 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:06 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-11 00:00:00 to 2014-02-11 00:00:00 (US Central Time). | 2016-03-17 17:16:06 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:06 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-12 00:00:00 to 2014-02-12 00:00:00 (US Central Time). | 2016-03-17 17:16:06 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-13 00:00:00 to 2014-02-13 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-14 00:00:00 to 2014-02-14 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-15 00:00:00 to 2014-02-15 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-16 00:00:00 to 2014-02-16 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-17 00:00:00 to 2014-02-17 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-18 00:00:00 to 2014-02-18 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-19 00:00:00 to 2014-02-19 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-20 00:00:00 to 2014-02-20 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:07 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-21 00:00:00 to 2014-02-21 00:00:00 (US Central Time). | 2016-03-17 17:16:07 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-22 00:00:00 to 2014-02-22 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-23 00:00:00 to 2014-02-23 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-24 00:00:00 to 2014-02-24 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-25 00:00:00 to 2014-02-25 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-26 00:00:00 to 2014-02-26 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-27 00:00:00 to 2014-02-27 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-02-28 00:00:00 to 2014-02-28 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-01 00:00:00 to 2014-03-01 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:08 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-02 00:00:00 to 2014-03-02 00:00:00 (US Central Time). | 2016-03-17 17:16:08 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-03 00:00:00 to 2014-03-03 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-04 00:00:00 to 2014-03-04 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-05 00:00:00 to 2014-03-05 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-06 00:00:00 to 2014-03-06 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-07 00:00:00 to 2014-03-07 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-08 00:00:00 to 2014-03-08 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-09 00:00:00 to 2014-03-09 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-10 00:00:00 to 2014-03-10 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:09 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-11 00:00:00 to 2014-03-11 00:00:00 (US Central Time). | 2016-03-17 17:16:09 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-12 00:00:00 to 2014-03-12 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-13 00:00:00 to 2014-03-13 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-14 00:00:00 to 2014-03-14 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-15 00:00:00 to 2014-03-15 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-16 00:00:00 to 2014-03-16 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-17 00:00:00 to 2014-03-17 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-18 00:00:00 to 2014-03-18 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-19 00:00:00 to 2014-03-19 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:10 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-20 00:00:00 to 2014-03-20 00:00:00 (US Central Time). | 2016-03-17 17:16:10 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-21 00:00:00 to 2014-03-21 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-22 00:00:00 to 2014-03-22 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-23 00:00:00 to 2014-03-23 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-24 00:00:00 to 2014-03-24 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-25 00:00:00 to 2014-03-25 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-26 00:00:00 to 2014-03-26 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-27 00:00:00 to 2014-03-27 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-28 00:00:00 to 2014-03-28 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-29 00:00:00 to 2014-03-29 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:11 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-30 00:00:00 to 2014-03-30 00:00:00 (US Central Time). | 2016-03-17 17:16:11 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-03-31 00:00:00 to 2014-03-31 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-01 00:00:00 to 2014-04-01 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-02 00:00:00 to 2014-04-02 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-03 00:00:00 to 2014-04-03 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-04 00:00:00 to 2014-04-04 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-05 00:00:00 to 2014-04-05 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-06 00:00:00 to 2014-04-06 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-07 00:00:00 to 2014-04-07 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:12 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-08 00:00:00 to 2014-04-08 00:00:00 (US Central Time). | 2016-03-17 17:16:12 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-09 00:00:00 to 2014-04-09 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-10 00:00:00 to 2014-04-10 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-11 00:00:00 to 2014-04-11 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-12 00:00:00 to 2014-04-12 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-13 00:00:00 to 2014-04-13 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-14 00:00:00 to 2014-04-14 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-15 00:00:00 to 2014-04-15 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-16 00:00:00 to 2014-04-16 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:13 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-17 00:00:00 to 2014-04-17 00:00:00 (US Central Time). | 2016-03-17 17:16:13 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-18 00:00:00 to 2014-04-18 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-19 00:00:00 to 2014-04-19 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-20 00:00:00 to 2014-04-20 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-21 00:00:00 to 2014-04-21 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-22 00:00:00 to 2014-04-22 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-23 00:00:00 to 2014-04-23 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-24 00:00:00 to 2014-04-24 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-25 00:00:00 to 2014-04-25 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:14 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-26 00:00:00 to 2014-04-26 00:00:00 (US Central Time). | 2016-03-17 17:16:14 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-27 00:00:00 to 2014-04-27 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-28 00:00:00 to 2014-04-28 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-29 00:00:00 to 2014-04-29 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-04-30 00:00:00 to 2014-04-30 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-01 00:00:00 to 2014-05-01 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-02 00:00:00 to 2014-05-02 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-03 00:00:00 to 2014-05-03 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-04 00:00:00 to 2014-05-04 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:15 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-05 00:00:00 to 2014-05-05 00:00:00 (US Central Time). | 2016-03-17 17:16:15 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-06 00:00:00 to 2014-05-06 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-07 00:00:00 to 2014-05-07 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-08 00:00:00 to 2014-05-08 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-09 00:00:00 to 2014-05-09 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-10 00:00:00 to 2014-05-10 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-11 00:00:00 to 2014-05-11 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-12 00:00:00 to 2014-05-12 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-13 00:00:00 to 2014-05-13 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:16 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-14 00:00:00 to 2014-05-14 00:00:00 (US Central Time). | 2016-03-17 17:16:16 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-15 00:00:00 to 2014-05-15 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-16 00:00:00 to 2014-05-16 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-17 00:00:00 to 2014-05-17 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-18 00:00:00 to 2014-05-18 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-19 00:00:00 to 2014-05-19 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-20 00:00:00 to 2014-05-20 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-21 00:00:00 to 2014-05-21 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-22 00:00:00 to 2014-05-22 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:17 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-23 00:00:00 to 2014-05-23 00:00:00 (US Central Time). | 2016-03-17 17:16:17 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-24 00:00:00 to 2014-05-24 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-25 00:00:00 to 2014-05-25 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-26 00:00:00 to 2014-05-26 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-27 00:00:00 to 2014-05-27 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-28 00:00:00 to 2014-05-28 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-29 00:00:00 to 2014-05-29 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-30 00:00:00 to 2014-05-30 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-05-31 00:00:00 to 2014-05-31 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:18 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-01 00:00:00 to 2014-06-01 00:00:00 (US Central Time). | 2016-03-17 17:16:18 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-02 00:00:00 to 2014-06-02 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-03 00:00:00 to 2014-06-03 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-04 00:00:00 to 2014-06-04 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-05 00:00:00 to 2014-06-05 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-06 00:00:00 to 2014-06-06 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-07 00:00:00 to 2014-06-07 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-08 00:00:00 to 2014-06-08 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-09 00:00:00 to 2014-06-09 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:19 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-10 00:00:00 to 2014-06-10 00:00:00 (US Central Time). | 2016-03-17 17:16:19 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-11 00:00:00 to 2014-06-11 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-12 00:00:00 to 2014-06-12 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-13 00:00:00 to 2014-06-13 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-14 00:00:00 to 2014-06-14 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-15 00:00:00 to 2014-06-15 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-16 00:00:00 to 2014-06-16 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-17 00:00:00 to 2014-06-17 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-18 00:00:00 to 2014-06-18 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:20 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-19 00:00:00 to 2014-06-19 00:00:00 (US Central Time). | 2016-03-17 17:16:20 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-20 00:00:00 to 2014-06-20 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-21 00:00:00 to 2014-06-21 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-22 00:00:00 to 2014-06-22 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-23 00:00:00 to 2014-06-23 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-24 00:00:00 to 2014-06-24 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-25 00:00:00 to 2014-06-25 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-26 00:00:00 to 2014-06-26 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-27 00:00:00 to 2014-06-27 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:21 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-28 00:00:00 to 2014-06-28 00:00:00 (US Central Time). | 2016-03-17 17:16:21 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-29 00:00:00 to 2014-06-29 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-06-30 00:00:00 to 2014-06-30 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-01 00:00:00 to 2014-07-01 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-02 00:00:00 to 2014-07-02 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-03 00:00:00 to 2014-07-03 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-04 00:00:00 to 2014-07-04 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-05 00:00:00 to 2014-07-05 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-06 00:00:00 to 2014-07-06 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:22 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-07 00:00:00 to 2014-07-07 00:00:00 (US Central Time). | 2016-03-17 17:16:22 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-08 00:00:00 to 2014-07-08 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-09 00:00:00 to 2014-07-09 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-10 00:00:00 to 2014-07-10 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-11 00:00:00 to 2014-07-11 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-12 00:00:00 to 2014-07-12 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-13 00:00:00 to 2014-07-13 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-14 00:00:00 to 2014-07-14 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-15 00:00:00 to 2014-07-15 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:23 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-16 00:00:00 to 2014-07-16 00:00:00 (US Central Time). | 2016-03-17 17:16:23 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-17 00:00:00 to 2014-07-17 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-18 00:00:00 to 2014-07-18 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-19 00:00:00 to 2014-07-19 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-20 00:00:00 to 2014-07-20 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-21 00:00:00 to 2014-07-21 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-22 00:00:00 to 2014-07-22 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-23 00:00:00 to 2014-07-23 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-24 00:00:00 to 2014-07-24 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:24 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-25 00:00:00 to 2014-07-25 00:00:00 (US Central Time). | 2016-03-17 17:16:24 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-26 00:00:00 to 2014-07-26 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-27 00:00:00 to 2014-07-27 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-28 00:00:00 to 2014-07-28 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-29 00:00:00 to 2014-07-29 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-30 00:00:00 to 2014-07-30 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-07-31 00:00:00 to 2014-07-31 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-01 00:00:00 to 2014-08-01 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-02 00:00:00 to 2014-08-02 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:25 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-03 00:00:00 to 2014-08-03 00:00:00 (US Central Time). | 2016-03-17 17:16:25 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-04 00:00:00 to 2014-08-04 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-05 00:00:00 to 2014-08-05 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-06 00:00:00 to 2014-08-06 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-07 00:00:00 to 2014-08-07 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-08 00:00:00 to 2014-08-08 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-09 00:00:00 to 2014-08-09 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-10 00:00:00 to 2014-08-10 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-11 00:00:00 to 2014-08-11 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:26 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-12 00:00:00 to 2014-08-12 00:00:00 (US Central Time). | 2016-03-17 17:16:26 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-13 00:00:00 to 2014-08-13 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-14 00:00:00 to 2014-08-14 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-15 00:00:00 to 2014-08-15 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-16 00:00:00 to 2014-08-16 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-17 00:00:00 to 2014-08-17 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-18 00:00:00 to 2014-08-18 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-19 00:00:00 to 2014-08-19 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-20 00:00:00 to 2014-08-20 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:27 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-21 00:00:00 to 2014-08-21 00:00:00 (US Central Time). | 2016-03-17 17:16:27 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-22 00:00:00 to 2014-08-22 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-23 00:00:00 to 2014-08-23 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-24 00:00:00 to 2014-08-24 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-25 00:00:00 to 2014-08-25 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-26 00:00:00 to 2014-08-26 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-27 00:00:00 to 2014-08-27 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-28 00:00:00 to 2014-08-28 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-29 00:00:00 to 2014-08-29 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-30 00:00:00 to 2014-08-30 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:28 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-08-31 00:00:00 to 2014-08-31 00:00:00 (US Central Time). | 2016-03-17 17:16:28 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-01 00:00:00 to 2014-09-01 00:00:00 (US Central Time). | 2016-03-17 17:16:29 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-02 00:00:00 to 2014-09-02 00:00:00 (US Central Time). | 2016-03-17 17:16:29 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-03 00:00:00 to 2014-09-03 00:00:00 (US Central Time). | 2016-03-17 17:16:29 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-04 00:00:00 to 2014-09-04 00:00:00 (US Central Time). | 2016-03-17 17:16:29 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-05 00:00:00 to 2014-09-05 00:00:00 (US Central Time). | 2016-03-17 17:16:29 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-06 00:00:00 to 2014-09-06 00:00:00 (US Central Time). | 2016-03-17 17:16:29 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-07 00:00:00 to 2014-09-07 00:00:00 (US Central Time). | 2016-03-17 17:16:29 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-08 00:00:00 to 2014-09-08 00:00:00 (US Central Time). | 2016-03-17 17:16:29 HD Request # 42 | Total records received: 0 | 2016-03-17 17:16:29 HD Request # 42 | Requesting historical Tick data for FESX.20160300.E_INX from 2014-09-09 00:00:00 to 2014-09-09 00:00:00 (US Central Time). | 2016-03-17 17:16:29 |
[2016-03-17 17:24:09] |
Reduce the Global Settings >> Data/Trade Service Settings >> Maximum Intraday Days to Download >> 1 Tick Data to 30. After that reconnect to the data feed: https://www.sierrachart.com/index.php?page=doc/doc_FileMenu.html#ProcedureToReconnect Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-17 17:24:31
[2016-03-17 17:29:09] |
Meritus - Posts: 164 |
OK its now correctly updating with the last few upticks in March FESX. Thank you. Should the issue recur I'll let you know.
