Date/Time: Thu, 24 Sep 2026 05:00:50 +0000
Using same data files folder for 2 instances of Sierra Chart
View Count: 906
[2016-03-17 05:10:47]
rc7rader - Posts: 145
I have been using the same data files folder for 2 instances of Sierra Chart for a long time. I have used different symbols on the 2 instances without problems. Lately, I see a need to have some symbols loaded on both instances. I trade from both instances. My question is will there be a problem if I use the same symbols simultaneously on the 2 instances of Sierra Chart?
[2016-03-17 05:24:12]
The answer from us is always going to be that you will have problems with this and this is unsupported.
We will not help with any consequences of doing this.
