Date/Time: Sun, 12 Jan 2025 13:01:57 +0000
set up max position and loss
View Count: 1133
[2013-07-03 14:54:39] |
User93731 - Posts: 81 |
Hi: Is there a feature on SC that I could set up max position and loss which allows SC to automatically flat my positions on my SIM account for the sake of practice? Best, Hiwhited |
[2013-07-03 19:01:44] |
No, this is not supported.
[2017-02-17 22:48:54] |
User970210 - Posts: 88 |
It is very useful risk management tool. Any plan to add it in the future?
[2017-02-17 23:07:01] |
This is now supported: Global Profit/Loss Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
