Date/Time: Fri, 27 Dec 2024 02:36:20 +0000
How to change tick increment display on sierra charts?
View Count: 1033
[2016-03-17 02:07:15]
User818051 - Posts: 4
Hello I am trying to figure out how to display the proper tick value for Crude oil on the right side of my chart. Currently it shows increments in .10 cents value versus .01 cent.
See screenshot for reference.
imageSierra chart price panel.jpg / V - Attached On 2016-03-17 02:06:29 UTC - Size: 380.18 KB - 356 views
[2016-03-17 04:46:38]
You can change this with the Scale Increment setting.
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html
