Date/Time: Fri, 27 Dec 2024 02:33:46 +0000
I cant connect to Interactive brokers
View Count: 776
[2016-03-16 16:19:13] |
User638756 - Posts: 52 |
I cant connect to Interactive brokers, worked well last night. I am using the gateway. Software version: 1382 | 2016-03-16 16:13:47 Uses New Spreadsheets | 2016-03-16 16:13:47 Usage end date: 2016-04-14 | 2016-03-16 16:13:47 Enabled for: Advanced Features. | 2016-03-16 16:13:47 Enabled for: Sierra Chart Historical Data Service. | 2016-03-16 16:13:47 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-03-16 16:13:47 Current selected Data/Trading service: Interactive Brokers | 2016-03-16 16:13:47 Chart Update Interval: 500 | 2016-03-16 16:13:47 Time Zone: +00:00:00 (UTC+00) | 2016-03-16 16:13:47 2016-03-16 11:13:51 Local computer time | 2016-03-16 16:13:47 2016-03-16 16:13:51 Local computer time in UTC | 2016-03-16 16:13:47 2016-03-16 16:13:51 Local computer time in SC Time Zone | 2016-03-16 16:13:47 2016-03-16 16:13:52 Server time in UTC | 2016-03-16 16:13:47 Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-03-16 16:13:47 Program path: C:\SierraChart\ | 2016-03-16 16:13:47 Data Files path: C:\SierraChart\Data\ | 2016-03-16 16:13:47 OS Version Number: 6.2 | 2016-03-16 16:13:47 Locale Information: C | 2016-03-16 16:13:47 Checking for new symbol settings for ib | 2016-03-16 16:13:47 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-03-16 16:13:47 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-03-16 16:13:47 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-03-16 16:13:47 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-03-16 16:13:47 Symbol settings are up-to-date for ib | 2016-03-16 16:13:52 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:13:56 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-03-16 16:13:57 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-03-16 16:13:57 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-03-16 16:13:57 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-03-16 16:13:57 Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:13:57 Socket (4) | Shutdown and closed. | 2016-03-16 16:13:57 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:13:57 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:13:57 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:13:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:13:57 Interactive Brokers | Disconnected. | 2016-03-16 16:13:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:13:57 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:00 Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:01 Socket (5) | Shutdown and closed. | 2016-03-16 16:14:01 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:01 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:01 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:01 Interactive Brokers | Disconnected. | 2016-03-16 16:14:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:01 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:04 Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:05 Socket (6) | Shutdown and closed. | 2016-03-16 16:14:05 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:05 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:05 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:05 Interactive Brokers | Disconnected. | 2016-03-16 16:14:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:05 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:08 Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:09 Socket (7) | Shutdown and closed. | 2016-03-16 16:14:09 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:09 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:09 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:09 Interactive Brokers | Disconnected. | 2016-03-16 16:14:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:09 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:12 Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:13 Socket (8) | Shutdown and closed. | 2016-03-16 16:14:13 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:13 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:13 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:13 Interactive Brokers | Disconnected. | 2016-03-16 16:14:13 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:13 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:16 Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:17 Socket (9) | Shutdown and closed. | 2016-03-16 16:14:17 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:17 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:17 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:17 Interactive Brokers | Disconnected. | 2016-03-16 16:14:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:17 File >> Disconnect selected. | 2016-03-16 16:14:20 Interactive Brokers | Disconnected. | 2016-03-16 16:14:20 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:26 Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:27 Socket (10) | Shutdown and closed. | 2016-03-16 16:14:27 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:27 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:27 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:27 Interactive Brokers | Disconnected. | 2016-03-16 16:14:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:27 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:30 Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:31 Socket (11) | Shutdown and closed. | 2016-03-16 16:14:31 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:31 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:31 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:31 Interactive Brokers | Disconnected. | 2016-03-16 16:14:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:31 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:34 Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:35 Socket (12) | Shutdown and closed. | 2016-03-16 16:14:35 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:35 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:35 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:35 Interactive Brokers | Disconnected. | 2016-03-16 16:14:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:35 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:38 Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:39 Socket (13) | Shutdown and closed. | 2016-03-16 16:14:39 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:39 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:39 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:39 Interactive Brokers | Disconnected. | 2016-03-16 16:14:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:39 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:42 Socket (14) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:43 Socket (14) | Shutdown and closed. | 2016-03-16 16:14:43 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:43 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:43 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:43 Interactive Brokers | Disconnected. | 2016-03-16 16:14:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:43 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:46 Socket (15) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:47 Socket (15) | Shutdown and closed. | 2016-03-16 16:14:47 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:47 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:47 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:47 Interactive Brokers | Disconnected. | 2016-03-16 16:14:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:47 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:50 Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:51 Socket (16) | Shutdown and closed. | 2016-03-16 16:14:51 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:51 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:51 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:51 Interactive Brokers | Disconnected. | 2016-03-16 16:14:51 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:51 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:54 Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:55 Socket (17) | Shutdown and closed. | 2016-03-16 16:14:55 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:55 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:55 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:55 Interactive Brokers | Disconnected. | 2016-03-16 16:14:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:55 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:14:58 Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:14:59 Socket (18) | Shutdown and closed. | 2016-03-16 16:14:59 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:14:59 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:14:59 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:14:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:14:59 Interactive Brokers | Disconnected. | 2016-03-16 16:14:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:14:59 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:02 Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:03 Socket (19) | Shutdown and closed. | 2016-03-16 16:15:03 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:03 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:03 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:03 Interactive Brokers | Disconnected. | 2016-03-16 16:15:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:03 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:06 Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:07 Socket (20) | Shutdown and closed. | 2016-03-16 16:15:07 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:07 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:07 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:07 Interactive Brokers | Disconnected. | 2016-03-16 16:15:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:07 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:10 Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:11 Socket (21) | Shutdown and closed. | 2016-03-16 16:15:11 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:11 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:11 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:11 Interactive Brokers | Disconnected. | 2016-03-16 16:15:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:11 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:14 Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:15 Socket (22) | Shutdown and closed. | 2016-03-16 16:15:15 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:15 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:15 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:15 Interactive Brokers | Disconnected. | 2016-03-16 16:15:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:15 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:18 Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:19 Socket (23) | Shutdown and closed. | 2016-03-16 16:15:19 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:19 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:19 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:19 Interactive Brokers | Disconnected. | 2016-03-16 16:15:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:19 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:22 Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:23 Socket (24) | Shutdown and closed. | 2016-03-16 16:15:23 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:23 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:23 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:23 Interactive Brokers | Disconnected. | 2016-03-16 16:15:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:23 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:26 Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:27 Socket (25) | Shutdown and closed. | 2016-03-16 16:15:27 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:27 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:27 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:27 Interactive Brokers | Disconnected. | 2016-03-16 16:15:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:27 The above has been sent to support. | 2016-03-16 16:15:30 * HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-03-16 16:15:30 HTTP connection to www.sierrachart.com:80 (26) | Connected. | 2016-03-16 16:15:30 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:30 Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2016-03-16 16:15:31 Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:32 Socket (27) | Shutdown and closed. | 2016-03-16 16:15:32 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:32 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:32 Interactive Brokers | Disconnected. | 2016-03-16 16:15:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:32 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:35 Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:36 Socket (28) | Shutdown and closed. | 2016-03-16 16:15:36 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:36 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:36 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:36 Interactive Brokers | Disconnected. | 2016-03-16 16:15:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:36 HTTP connection to www.sierrachart.com:80 (26) | Closed. No error. | 2016-03-16 16:15:36 HTTP connection to www.sierrachart.com:80 (26) | Shutdown and closed. | 2016-03-16 16:15:36 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:39 Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:40 Socket (29) | Shutdown and closed. | 2016-03-16 16:15:40 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:40 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:40 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:40 Interactive Brokers | Disconnected. | 2016-03-16 16:15:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:40 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:43 Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:44 Socket (30) | Shutdown and closed. | 2016-03-16 16:15:44 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:44 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:44 Interactive Brokers | Disconnected. | 2016-03-16 16:15:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:44 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:47 Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:48 Socket (31) | Shutdown and closed. | 2016-03-16 16:15:48 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:48 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:48 Interactive Brokers | Disconnected. | 2016-03-16 16:15:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:48 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:51 Socket (33) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:52 Socket (33) | Shutdown and closed. | 2016-03-16 16:15:52 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:52 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:52 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:52 Interactive Brokers | Disconnected. | 2016-03-16 16:15:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:52 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:55 Socket (34) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:15:56 Socket (34) | Shutdown and closed. | 2016-03-16 16:15:56 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:15:56 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:15:56 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:15:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:15:56 Interactive Brokers | Disconnected. | 2016-03-16 16:15:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:15:56 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:15:59 Socket (35) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:00 Socket (35) | Shutdown and closed. | 2016-03-16 16:16:00 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:00 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:00 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:00 Interactive Brokers | Disconnected. | 2016-03-16 16:16:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:00 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:03 Socket (36) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:04 Socket (36) | Shutdown and closed. | 2016-03-16 16:16:04 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:04 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:04 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:04 Interactive Brokers | Disconnected. | 2016-03-16 16:16:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:04 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:07 Socket (37) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:08 Socket (37) | Shutdown and closed. | 2016-03-16 16:16:08 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:08 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:08 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:08 Interactive Brokers | Disconnected. | 2016-03-16 16:16:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:08 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:11 Socket (38) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:12 Socket (38) | Shutdown and closed. | 2016-03-16 16:16:12 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:12 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:12 Interactive Brokers | Disconnected. | 2016-03-16 16:16:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:12 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:15 Socket (39) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:16 Socket (39) | Shutdown and closed. | 2016-03-16 16:16:16 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:16 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:16 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:16 Interactive Brokers | Disconnected. | 2016-03-16 16:16:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:16 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:19 Socket (40) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:20 Socket (40) | Shutdown and closed. | 2016-03-16 16:16:20 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:20 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:20 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:20 Interactive Brokers | Disconnected. | 2016-03-16 16:16:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:20 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:23 Socket (41) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:24 Socket (41) | Shutdown and closed. | 2016-03-16 16:16:24 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:24 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:24 Interactive Brokers | Disconnected. | 2016-03-16 16:16:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:24 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:27 Socket (42) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:28 Socket (42) | Shutdown and closed. | 2016-03-16 16:16:28 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:28 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:28 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:28 Interactive Brokers | Disconnected. | 2016-03-16 16:16:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:28 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:31 Socket (43) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:32 Socket (43) | Shutdown and closed. | 2016-03-16 16:16:32 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:32 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:32 Interactive Brokers | Disconnected. | 2016-03-16 16:16:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:32 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:35 Socket (44) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:36 Socket (44) | Shutdown and closed. | 2016-03-16 16:16:36 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:36 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:36 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:36 Interactive Brokers | Disconnected. | 2016-03-16 16:16:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:36 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:39 Socket (45) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:40 Socket (45) | Shutdown and closed. | 2016-03-16 16:16:40 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:40 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:40 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:40 Interactive Brokers | Disconnected. | 2016-03-16 16:16:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:40 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:43 Socket (46) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:44 Socket (46) | Shutdown and closed. | 2016-03-16 16:16:44 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:44 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:44 Interactive Brokers | Disconnected. | 2016-03-16 16:16:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:44 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:47 Socket (47) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:48 Socket (47) | Shutdown and closed. | 2016-03-16 16:16:48 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:48 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:48 Interactive Brokers | Disconnected. | 2016-03-16 16:16:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:48 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:51 Socket (48) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:52 Socket (48) | Shutdown and closed. | 2016-03-16 16:16:52 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:52 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:52 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:52 Interactive Brokers | Disconnected. | 2016-03-16 16:16:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:52 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:55 Socket (49) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:16:56 Socket (49) | Shutdown and closed. | 2016-03-16 16:16:56 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:16:56 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:16:56 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:16:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:16:56 Interactive Brokers | Disconnected. | 2016-03-16 16:16:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:16:56 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:16:59 Socket (50) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:00 Socket (50) | Shutdown and closed. | 2016-03-16 16:17:00 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:00 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:00 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:00 Interactive Brokers | Disconnected. | 2016-03-16 16:17:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:00 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:03 Socket (51) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:04 Socket (51) | Shutdown and closed. | 2016-03-16 16:17:04 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:04 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:04 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:04 Interactive Brokers | Disconnected. | 2016-03-16 16:17:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:04 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:07 Socket (52) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:08 Socket (52) | Shutdown and closed. | 2016-03-16 16:17:08 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:08 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:08 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:08 Interactive Brokers | Disconnected. | 2016-03-16 16:17:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:08 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:11 Socket (53) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:12 Socket (53) | Shutdown and closed. | 2016-03-16 16:17:12 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:12 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:12 Interactive Brokers | Disconnected. | 2016-03-16 16:17:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:12 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:15 Socket (54) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:16 Socket (54) | Shutdown and closed. | 2016-03-16 16:17:16 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:16 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:16 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:16 Interactive Brokers | Disconnected. | 2016-03-16 16:17:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:16 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:19 Socket (55) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:20 Socket (55) | Shutdown and closed. | 2016-03-16 16:17:20 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:20 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:20 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:20 Interactive Brokers | Disconnected. | 2016-03-16 16:17:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:20 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:23 Socket (56) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:24 Socket (56) | Shutdown and closed. | 2016-03-16 16:17:24 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:24 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:24 Interactive Brokers | Disconnected. | 2016-03-16 16:17:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:24 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:27 Socket (57) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:28 Socket (57) | Shutdown and closed. | 2016-03-16 16:17:28 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:28 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:28 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:28 Interactive Brokers | Disconnected. | 2016-03-16 16:17:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:28 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:31 Socket (58) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:32 Socket (58) | Shutdown and closed. | 2016-03-16 16:17:32 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:32 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:32 Interactive Brokers | Disconnected. | 2016-03-16 16:17:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:32 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:35 Socket (59) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:36 Socket (59) | Shutdown and closed. | 2016-03-16 16:17:36 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:36 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:36 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:36 Interactive Brokers | Disconnected. | 2016-03-16 16:17:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:36 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:39 Socket (60) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:40 Socket (60) | Shutdown and closed. | 2016-03-16 16:17:40 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:40 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:40 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:40 Interactive Brokers | Disconnected. | 2016-03-16 16:17:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:40 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:43 Socket (61) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:44 Socket (61) | Shutdown and closed. | 2016-03-16 16:17:44 Interactive Brokers | Failed to connect to the data and trade server. | 2016-03-16 16:17:44 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-03-16 16:17:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-16 16:17:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-16 16:17:44 Interactive Brokers | Disconnected. | 2016-03-16 16:17:44 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-03-16 16:17:44 |
[2016-03-16 16:42:21] |
These are the relevant messages: Interactive Brokers: Connecting to 127.0.0.1:7496 | 2016-03-16 16:17:35
Socket (59) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-03-16 16:17:36 Follow through the instructions at step 22 here: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
