Date/Time: Fri, 27 Dec 2024 02:22:32 +0000
FDAX Volumen
View Count: 829
[2016-03-16 16:13:23]
User297539 - Posts: 55
Hi have the problem with the volume . If I FDAX Historical chart upload I have volume 128441 and if I Intraday Chart upload I get volume 71374
How does this happen?
image16-03-2016 17-02-46.png / V - Attached On 2016-03-16 16:11:54 UTC - Size: 100.91 KB - 273 views
image16-03-2016 17-03-37.png / V - Attached On 2016-03-16 16:12:03 UTC - Size: 102.36 KB - 277 views
[2016-03-16 18:12:09]
Refer to help topic 43.7:
https://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7
We see you are using TT Net. We do not think there is a problem with incomplete data from the data feed. So that part of the documentation does not apply.
