Date/Time: Fri, 20 Sep 2024 00:54:38 +0000
Number bar study for Stock
View Count: 1432
[2013-07-03 13:16:00] |
Moti - Posts: 63 |
Hello, I subscribe to Iqfeed to get tick by tick data for Stock , AAPL IBM MSFT and use the bid /ask Sierra studies Like: Nubmber bar Numbers bar calculated values Every time I add a study, all freeze , and I need to REstart Sierra ! Please help, Moti |
[2013-07-03 19:04:06] |
This is because there is a huge number of ticks when using a tick size of .01 for these high-priced stocks. Before applying the Volume by Price study or Numbers Bars study to the chart, go to Chart >> Chart Settings and set the Volume at Price Multiplier to at least 20. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-03 19:05:07
