Date/Time: Fri, 27 Dec 2024 02:35:32 +0000
User Email
View Count: 793
[2016-03-16 15:04:56] |
Sierra Chart - Max - Posts: 5769 |
My timing on my charts is all screwed up. The time across the bottom is
different on different charts. Also the timing shows gaps. It starts at 3-16 on the bottom goes :21 to :41 to 14:11. I've tried unloading and reloading charts and also updating sierra charts but nothing has worked to fix the problem what do I do? Sierra Chart Support |
[2016-03-16 17:37:15] |
You need to post on this Support Board. Here are instructions: Support Board Posting Information We need to see an image of the chart. Provide it following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
